TF330 Akiko C2P Compatibility (Turn Off Data Cache)
Hi all!
First of all thanks to terriblefire for the... terrible work and effort he has put into these boards, secondly thanks to alenppc for building the boards and shipping them super quickly!
After having a TF328 for some time, I couldn't resist getting a TF330 (delivered today). It should have the latest firmware.
The board seems to work, but I've noticed that the Akiko chip is not doing a proper C2P conversion anymore.
I've tested with DoomAttack (CD32 version), Wing Commander (patched) and Fusion (Mac emulator with the Akiko driver), and they all show garbage on the screen.
They all worked fine with the TF328. I've also tried the board with another riser, same issue.
So I wonder if it's:
0) a known problem or could someone else please verify if the same occurs to them?
1) a software issue? Is Akiko not supposed to work with anything above a 68020?
2) my combination of CD32 (Akiko rev.) and this board to prevent it from working?
3) a problem with one of the signals on the connector that I need to clean?
Let me know if there's anything I can do to give more informations/help.
Cheers!
Cheers!
- Admin sponsor
Re: TF330 Akiko C2P Compatibility
Does your CD-ROM drive still work? If so Akiko is probably working fine and the issue is something else.
Wow that's a quick reply! Yep, just verified, the CD seems to be working correctly. It's just the chunky to planar conversion performed by Akiko that is gone.terriblefire wrote: Tue Mar 26, 2019 8:16 pm Does your CD-ROM drive still work? If so Akiko is probably working fine and the issue is something else.
Thanks.
- Admin sponsor
In your early start menu do you have a 1 or a 2 for the product code for the RAM?nibiru wrote: Tue Mar 26, 2019 8:33 pmWow that's a quick reply! Yep, just verified, the CD seems to be working correctly. It's just the chunky to planar conversion performed by Akiko that is gone.terriblefire wrote: Tue Mar 26, 2019 8:16 pm Does your CD-ROM drive still work? If so Akiko is probably working fine and the issue is something else.
Thanks.
Turns out that someone posted an answer... yesterday.
Akiko doesn't like the DATA CACHE:
http://eab.abime.net/showpost.php?p=131 ... stcount=61
Turning it off, everything works again.
Thanks TerribleFire, maybe we can leave this here for people wondering, or add as a FAQ somewhere else!
Btw, I've got a Product-Code of 1 and Manufacturer 5080.
Cheers.
Cheers.
- Admin sponsor
Re: TF330 Akiko C2P Compatibility (Turn Off Data Cache)
Great.
You should try and get an upgrade to version 2. Its a good kick up the arse faster.
Yes, his board was shipped before v2 arrived... but I had no clue about data cache incompatibility. I am going to run some tests with v1 and v2 firmwares to see if there is any difference.
- Admin sponsor
The cache is inhibited for Akiko addresses but there is a "bug" in the 030 whereby if you write a longword to an address and certain caches are enabled then you will read that back always.. The address is effectively non-volatile. Some call it a bug.. Some call it a "feature".alenppc wrote: Tue Mar 26, 2019 8:58 pm Yes, his board was shipped before v2 arrived... but I had no clue about data cache incompatibility. I am going to run some tests with v1 and v2 firmwares to see if there is any difference.
http://eab.abime.net/showthread.php?t=56255
EDIT: Its one of the reasons the 030 was not wanted on the CD32 for so long...
Thanks everyone.
Should I try to flash the beta in the other thread then? I remember flashing the TF328 with my RaspPi, can I do the same?
- Admin sponsor
There is a newer one AlenPPC can give you.nibiru wrote: Tue Mar 26, 2019 9:20 pm Thanks everyone.
