I stumbled on this earlier today and wondered if this could be a possible alternative for large amounts of inexpensive RAM without having to mess with implementing DRAM/SDRAM controllers?
https://www.cypress.com/products/hyperram-memory
https://intelligenttoasters.blog/2018/1 ... e-part-38/
Regards
HyperRAM - Interesting memory tech that may simplify accelerator design?
- RogerWilco486
- 8 Bit Dreams
- Moderator Team
Re: HyperRAM - Interesting memory tech that may simplify accelerator design?
Forget about DIY then.. It's BGA, dude.. How many people can do BGA?
- RogerWilco486
Well, I can.
These chips are only 24-ball and would be quite easy to fit with balls by hand using only tweezers and hot-air.
Also many PCB houses will fit BGA parts at the time of manufacture for a small fee, even a single component is usually OK with them. An open source FPGA based direct-sampling HF transceiver project I participated in had Elecrow do this in lots of 100 and the cost was very reasonable.
In any event, I'm not necessarily suggesting it as a solution I just thought the concept of HyperRAM sounded pretty neat.
- Admin sponsor
Looks more complex than SDRAM.. from a brief reading of it. Requires differential clocks,
Nice tech but its not going to simplify the designs
