UNIVERSAL ST/F/M 4MB RAM MMU ADAPTER
lrodriguezrullan
I am having trouble with this kit. I am getting a black screen on my 1040 STF.
I did check that every pin on the cable is connected to a pin on the shifter board. It seems to be OK. I lifted the R59, R60, R61, R71, R72, and R73 resistors and connected them to 5V.
Re: UNIVERSAL ST/F/M 4MB RAM MMU ADAPTER
Please post a image of it all..
Should be R60, R61 for bank 1 and R71, R72 for bank 2 to be disabled. But it all depends on motherboard revisions.
EDIT: Hmm, checked exxos blogpost about fitting the 4MB expansion and you have done what he has done so I don't know. According to Marpet/Frontier board you leave out R59 and R73.
We need a image of what he has and done.
http://www.exxosforum.co.uk/atari/last/4MBMMU/index.htm
As resistor numbers and even orientation of the MMU can be different across motherboard revisions.
lrodriguezrullan
Please find some photos of what I did.
Do you have higher resolution images you can send me in PM ? ( you may need to zip them if large images wont upload)
lrodriguezrullan
I don't have better photos right now. I will have to retake them.
lrodriguezrullan
Is there something that you are looking for that I can clarify, while I retake the photos? Thanks.
1st and 4th image...lrodriguezrullan wrote: Mon Mar 11, 2019 9:56 pm Is there something that you are looking for that I can clarify, while I retake the photos? Thanks.
It looks connected up right, but cant tell much else form the images currently.
lrodriguezrullan
I just sent you the higher resolution images via private message.
I wasn't sure about my soldering, so I used a multitester to test continuity from each pin in the ribbon cable to the shifter socket. The results are as follows:
Cable 1 -> Socket 32
Cable 2 -> Socket 33
Cable 3 -> Socket 34
Cable 4 -> Socket 35
Cable 5 -> Socket 36
Cable 6 -> Socket 37
Cable 7 -> Socket 38
Cable 8 -> Socket 39
Cable 9 -> Socket 30
Cable 10 -> Socket 29
Cable 11 -> Socket 28
Cable 12 -> Socket 27
Cable 13 -> Socket 26
Cable 14 -> Socket 25
Cable 15 -> Socket 24
Cable 16 -> Socket 23
That is assuming that the cable pins are numbered 1 to 16 from left to right and that the socket pins are numbered from 1 to 40 counter clockwise starting with the bottom left corner of the socket.
Does this look correct?
