MuteDucks Build Log
TF530 - 63030 + RAM Board
muteDuck
MuteDucks Build Log
Post by muteDuck »
Starting a tf530 board build so at moment got the PCB and looking to order parts. Got one quick question which is for the cpld have I found the right one on digikey:
https://www.digikey.co.uk/product-detai ... -ND/826991
Now the other suggested products may suggest I have as some of the other components such as the sram is showing up there.
muteDuck
Re: MuteDucks Build Log
Post by muteDuck »
So finally got a diagrom and plopped it in to the 500+. So turns out there looks to be potential memory issue although seeing some evidance of battery damage on the board:
https://photos.app.goo.gl/r2J7fsx2qn2bssoWA
 @U
Garbage before this text was binary numbers: 1, 2, 4, 8, 16, 32, 64, 128, 240, 15, 170 and 85
To help you find biterrors to paula. Now starting normal startuptext etc
[0mAmiga DiagROM V1.1 - 27-Oct-18  - By John (Chucky/The Gang) Hertell
Testing if serial loopbackadapter is installed: <> NOT DETECTED
- Parallel Code $ff - Start of ROM, CPU Seems somewhat alive
    Checking status of mousebuttons for different startups:
    Set all Interrupt enablebits (INTENA $dff09a) to Disabled: Done
    Set all Interrupt requestbits (INTREQ $dff09c) to Disabled: Done
    Set all DMA enablebits (DMACON $dff096) to Disabled: Done
Testing if OVL is working: OK
- Parallel Code $fe - Test UDS/LDS line
  - Test of writing word $FFFF to $400 OK
  - Test of writing word $00FF to $400 OK
  - Test of writing word $FF00 to $400 OK
  - Test of writing word $0000 to $400 OK
  - Test of writing byte (even) $ff to $400 OK
  - Test of writing byte (odd) $ff to $401 OK
- Parallel Code $fd - Start of chipmemdetection
Addr $00000400  Write: $AAAAAAAA  Read: $AAAAFFAA  FAILED
Addr $00000400  Write: $55555555  Read: $5555FF55  FAILED
Addr $00000400  Write: $F0F0F0F0  Read: $F1F0FFF0  FAILED
Addr $00000400  Write: $0F0F0F0F  Read: $0F0FFF0F  FAILED
Addr $00000400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00008400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00008400  Write: $55555555  Read: $5555FF55  FAILED
Addr $00008400  Write: $F0F0F0F0  Read: $F1F0FFF0  FAILED
Addr $00008400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00008400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00010400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00010400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00010400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00010400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00010400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00018400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00018400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00018400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00018400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00018400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00020400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00020400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00020400  Write: $F0F0F0F0  Read: $F3F0FFF0  FAILED
Addr $00020400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00020400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00028400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00028400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00028400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00028400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00028400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00030400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00030400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00030400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00030400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00030400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00038400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00038400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00038400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00038400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00038400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00040400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00040400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00040400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00040400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00040400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00048400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00048400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00048400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00048400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00048400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00050400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00050400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00050400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00050400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00050400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00058400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00058400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00058400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00058400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00058400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00060400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00060400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00060400  Write: $F0F0F0F0  Read: $F3F0FFF0  FAILED
Addr $00060400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00060400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00068400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00068400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00068400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00068400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00068400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00070400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00070400  Write: $55555555  Read: $5555FF55  FAILED
Addr $00070400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00070400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00070400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00078400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00078400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00078400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00078400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00078400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00080400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00080400  Write: $55555555  Read: $5555FF55  FAILED
Addr $00080400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00080400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00080400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00088400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00088400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00088400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00088400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00088400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00090400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00090400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00090400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00090400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00090400  Write: $00000000  Read: $4000FF00  FAILED
Addr $00098400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00098400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00098400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00098400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00098400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000A0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000A0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000A0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000A0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000A0400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000A8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000A8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000A8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000A8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000A8400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000B0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000B0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000B0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000B0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000B0400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000B8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000B8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000B8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000B8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000B8400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000C0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000C0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000C0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000C0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000C0400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000C8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000C8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000C8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000C8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000C8400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000D0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000D0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000D0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000D0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000D0400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000D8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000D8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000D8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000D8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000D8400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000E0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000E0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000E0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000E0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000E0400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000E8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000E8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000E8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000E8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000E8400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000F0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000F0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000F0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000F0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000F0400  Write: $00000000  Read: $0000FF00  FAILED
Addr $000F8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $000F8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $000F8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $000F8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $000F8400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00100400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00100400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00100400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00100400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00100400  Write: $00000000  Read: $4000FF00  FAILED
Addr $00108400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00108400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00108400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00108400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00108400  Write: $00000000  Read: $4000FF00  FAILED
Addr $00110400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00110400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00110400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00110400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00110400  Write: $00000000  Read: $C000FF00  FAILED
Addr $00118400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00118400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00118400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00118400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00118400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00120400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00120400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00120400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00120400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00120400  Write: $00000000  Read: $4000FF00  FAILED
Addr $00128400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00128400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00128400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00128400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00128400  Write: $00000000  Read: $C000FF00  FAILED
Addr $00130400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00130400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00130400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00130400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00130400  Write: $00000000  Read: $4000FF00  FAILED
Addr $00138400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00138400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00138400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00138400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00138400  Write: $00000000  Read: $4000FF00  FAILED
Addr $00140400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00140400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00140400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00140400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00140400  Write: $00000000  Read: $FE00FF00  FAILED
Addr $00148400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00148400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00148400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00148400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00148400  Write: $00000000  Read: $FC00FF00  FAILED
Addr $00150400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00150400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00150400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00150400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00150400  Write: $00000000  Read: $FC00FF00  FAILED
Addr $00158400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00158400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00158400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00158400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00158400  Write: $00000000  Read: $4000FF00  FAILED
Addr $00160400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00160400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00160400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00160400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00160400  Write: $00000000  Read: $FC00FF00  FAILED
Addr $00168400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00168400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00168400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00168400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00168400  Write: $00000000  Read: $C000FF00  FAILED
Addr $00170400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00170400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00170400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00170400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00170400  Write: $00000000  Read: $FC00FF00  FAILED
Addr $00178400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00178400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00178400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00178400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00178400  Write: $00000000  Read: $C000FF00  FAILED
Addr $00180400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00180400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00180400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00180400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00180400  Write: $00000000  Read: $C000FF00  FAILED
Addr $00188400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00188400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00188400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00188400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00188400  Write: $00000000  Read: $C000FF00  FAILED
Addr $00190400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00190400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00190400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00190400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00190400  Write: $00000000  Read: $0000FF00  FAILED
Addr $00198400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $00198400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $00198400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $00198400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $00198400  Write: $00000000  Read: $0000FF00  FAILED
Addr $001A0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001A0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001A0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001A0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001A0400  Write: $00000000  Read: $C000FF00  FAILED
Addr $001A8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001A8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001A8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001A8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001A8400  Write: $00000000  Read: $4000FF00  FAILED
Addr $001B0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001B0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001B0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001B0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001B0400  Write: $00000000  Read: $0000FF00  FAILED
Addr $001B8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001B8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001B8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001B8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001B8400  Write: $00000000  Read: $0000FF00  FAILED
Addr $001C0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001C0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001C0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001C0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001C0400  Write: $00000000  Read: $4000FF00  FAILED
Addr $001C8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001C8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001C8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001C8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001C8400  Write: $00000000  Read: $4000FF00  FAILED
Addr $001D0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001D0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001D0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001D0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001D0400  Write: $00000000  Read: $4000FF00  FAILED
Addr $001D8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001D8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001D8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001D8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001D8400  Write: $00000000  Read: $C000FF00  FAILED
Addr $001E0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001E0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001E0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001E0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001E0400  Write: $00000000  Read: $E000FF00  FAILED
Addr $001E8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001E8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001E8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001E8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001E8400  Write: $00000000  Read: $0000FF00  FAILED
Addr $001F0400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001F0400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001F0400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001F0400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001F0400  Write: $00000000  Read: $0000FF00  FAILED
Addr $001F8400  Write: $AAAAAAAA  Read: $FFAAFFAA  FAILED
Addr $001F8400  Write: $55555555  Read: $FF55FF55  FAILED
Addr $001F8400  Write: $F0F0F0F0  Read: $FFF0FFF0  FAILED
Addr $001F8400  Write: $0F0F0F0F  Read: $FE0FFF0F  FAILED
Addr $001F8400  Write: $00000000  Read: $0000FF00  FAILED
NO Chipmem detected
- Parallel Code $fc - Start of non autoconfig fastmemdetection (as no chip found/startup check)
  - No fastmem found, Autoconfig ram NOT checked
- Parallel Code $fb - Memorydetection done
- Parallel Code $80 - NO Chipmem detected
- NO MEMORY FOUND - HALTING SYSTEM
kludge
Post by kludge »
muteDuck wrote: Sat Feb 23, 2019 11:53 am Got one quick question which is for the cpld have I found the right one on digikey:
I'm no expert, but that looks like the right part, indeed.
My lack of focus:
Return to “TF530”
