Falcon VGA 3-in-1 monitor adapter by dhedberg
Various other hardware solutions.
Locked
This adapter plugs into the monitor port and makes it possible to connect monitors using a standard VGA cable.
It also features a switch for changing between RGB and VGA video modes, allowing users with multi-sync monitors to take advantage of all video modes of the Falcon030. Finally, the adapter provides a higher frequency pixel clock signal to the Falcon030 video chip, making it possible to achieve higher screen resolutions. The adapter is compatible with the Blow-Up software and Videlity software (used to configure the enhanced video modes).
More information here:
3-IN-1.PDF
(805.16 KiB) Downloaded 484 times
The Blow-Up software has been released by its author and can be copied freely.
Please read the READ-ME.TXT file included in the BLOWUP.ZIP archive for further instructions and a few example configurations (these require the 3-in-1 monitor adapter).
Software:
BLOWUP.ZIP
(289.65 KiB) Downloaded 324 times
Manual (German, original):
BLOWUP.PDF
(7.14 MiB) Downloaded 329 times
Manual (English, kindly provided by Saturnin51):
BLOWUP_E.PDF
(1.59 MiB) Downloaded 388 times
Store link:
https://www.exxosforum.co.uk/atari/store2/#0146
Locked
Return to “HARDWARE ESSENTIALS”
