Eagle libs - why you can't trust them
TQFP64 package.. Pads are not aligned correctly to device.. Just look at the overhang on the IC to the print out of the bads on the might hand side.
Its almost impossible to get the IC to "fit" that device as the whole package seems like 10% to small :roll:
rpineau
Re: Eagle libs - why you can't trust them
Post by rpineau »
That is really weird.
I've used the Eagle TQFP100 and that one was fine.
Same with the TQFP44 package.
TQFP64 has a pitch of 0.5mm center to center of pins. Pin width should be about 0.20 mm
proper dimension can be found in this doc : http://pdf.datasheetcatalog.com/datashe ... 806_DS.pdf
Make sure you didn't copy it from the LQFT of plain QFP as apparently there could be some differences ( 0.8mm pitch instead of 0.5mm).
rpineau
Post by rpineau »
If you copied it from another lib in Eagle, make sure you took the TQFP64-10x10 one.
rpineau wrote: Tue Jan 08, 2019 7:05 pm If you copied it from another lib in Eagle, make sure you took the TQFP64-10x10 one.
I used the one in the MC68K lib ...TQFP64
The 10x10 one is actually to small...
EDIT2:
Actually all the TQFP64 look like the exact same footprint, like its been copied/paste 100 times over various libs.. all are not correct :roll:
hmmm
This one seems a tiny larger
TQFP64-17X17 in renesas21
This one seems fine.. so will have to edit the 68K lib :roll:
rpineau
Post by rpineau »
May be I should make a proper one.
rpineau wrote: Tue Jan 08, 2019 7:42 pm That is really weird.
I've got the SEC CPU already in a lib, just the pcb footprint is wrong.
Added it in :)
rpineau
Post by rpineau »
:thumbup: :bravo:
Return to “ELECTRONICS”
