My CDTV Nightmare
My CDTV Nightmare
Ok.. So i've given the TF series a whirl on the CDTV and No joy at all.
I have probably got the wrong ROM etc installed but the machine just reboots and resets the CD Drive over and over.
I guess first thing i need is ROMS. What ROM chips to these badgers use?
EDIT: My kickstart roms are version 1.0... i guess this sucker isnt going to boot 030.
8 Bit Dreams
Re: TF534 on CDTV
Post by 8 Bit Dreams »
Ok,
You need 27C1000 or 27C1001, be careful, these are a bit tricky, becase some company's mixed pinouts for these two!
What YOU need are chips with Pin2 A16 and Pin24 should be !OE, however some company's have reverse these two pins, these will NOT work!
Alternatively You can build an adaptor and swap these in programmer (like i did) and it worked for me...
Re: TF534 on CDTV
OK i have DiagROM up and running.. noticed this
I wonder if the expansion roms think the base address for the CDTV control is always 0xEA0000.
Re: TF534 on CDTV
and now i completely killed the CDTV somehow..
oh well. back in the cupboard.
8 Bit Dreams
Re: TF534 on CDTV
terriblefire wrote: Sat Jan 05, 2019 6:26 pm I wonder if the expansion roms think the base address for the CDTV control is always 0xEA0000.
not sure, however, if You have a SCSI module plugged in (rear expansion slot) then You can boot from SCSI HD
terriblefire wrote: Sat Jan 05, 2019 6:35 pm and now i completely killed the CDTV somehow..
can You discribe more? Maybe You just unplugged Video expasion? CDTV will not work without it
Re: TF534 on CDTV
8 Bit Dreams wrote: Sat Jan 05, 2019 6:49 pm can You discribe more? Maybe You just unplugged Video expasion? CDTV will not work without it
I think I shorted 5V to ground and now the front panel does not power up at all and the fan ticks then comes on without the power button being on.
Its dead Jim.
EDIT: its probably a fuse somewhere but this thing looks too complex to disassemble with those connectors.
8 Bit Dreams
Re: TF534 on CDTV
Well,
if so - take a look on voltages on Your PSU, not sure are there any fuse or not... if it's not reparable - Ian Stedman has very nice power adapters for cdtv:
http://www.ianstedman.co.uk/Sales/sales.html
For only £9..
Re: TF534 on CDTV
Well it looks like that CDTV took out more than just itself... blew up my CF card.
What happened was I plugged in the CF adaptor 1 place "off". usually this causes the PSU to give up. But the CDTV had other ideas...
EDIT: if i do get this going again the PSU is getting chucked. Pile of crap.
utri007
Re: TF534 on CDTV
Post by utri007 »
Thanks for trying TF with CDTV. CDTV has very unique feature, compared to any other Amiga, it usually get wife's approve to be in living room. :)
So if you coul continue, please? Using it with plain 68000 is pain, so any acclerator would be nice improvement.
Re: TF534 on CDTV
I will indeed. But not while frustrated
Return to “TF534 (OBSOLETE)”
