exxos PSU 110V wiring
Repairs & upgrades.
Locked
NOTE: If anyone can has images of the original grey switching wiring with the exxos PSU wired at 110V, then please PM me..
NEW SWITCH MOUNTING (SPST)
The 110V transformer wiring is slightly different than the 230V one, but very similar. While the 230V transformer wires have BLUE and BROWN wires, the 110V has the same wires but paired with GREY and PURPLE.
NOTE: I strongly suggest fitting a new PSU switch when the PSU is fitted.
SWITCH
https://www.exxosforum.co.uk/atari/store2/#0032
PSU
https://www.exxosforum.co.uk/atari/store2/#0030
Re: exxos PSU 110V wiring
110V PRIMARY CONFIGURATION
Grey & Brown wired together.
Purple & Blue wired together.
Please note: Fitting is for guidance only. If not re-fitting the switch insulation boot, you must isolate mains connections with suitable heat shrink tubing . If not using a fused mains lead (no greater than 3amp fuse in the plug) , you should fit a 1 - 3 amp mains antisurge fuse in the live / hot wire between the mains connector and switch and insulate accordingly. Wires should be soldered at right angles on the switch.
GREY SWITCH DPST WIRING 110V
Thanks to @RetroPassionUK for the image.
@exxos As requested, please double check and let me know if there are any errors.
rubber_jonnie wrote: Tue Sep 27, 2022 1:58 pm @exxos As requested, please double check and let me know if there are any errors.
Looks correct!
:thanksyellow:
exxos wrote: Tue Sep 27, 2022 2:03 pm
Looks correct!
:thanksyellow:
Splendid
Locked
