TF534 vs Clockport issue
8 Bit Dreams
Post by 8 Bit Dreams »
Hi guys,
Got my hands on A500 Clockport modules, of course wanted to test them with the TF534 Accelerators..Well this duo isn't working atm unfortunately. If i understand correctly - Clockport uses interrupts to go thru CPU cycles, right?
Ps
This Clockport acts same as a standard A1200 Clockport and works fine otherwise. Tested USB keys, wireless keyboard, mouse, digital camera.. This is something what You don't want to miss once got it in Your hands..
Re: TF534 vs Clockport issue
Does it work with the 520/530?
8 Bit Dreams
will try to test with TF520 later, TF530 are sold out - unable to test.. have other Accelerators here - these are working ok,
a little slowdown was noticed though, but not critical.. Was aware there are USB solutions for Amiga, but was surprised how good Subway works on..
8 Bit Dreams
TF520 turned out not so easy to test with, since IDE device is needed (USB stack need to be installed) sold my last Oktagon AT Bus Clone card so unable to test..
TF520 + Kipper2k should work fine?
Return to “TF534 (OBSOLETE)”
