To route the actual PCB tracks we use the ROUTE tool. In the WIDTH menu bar I used 1.016 mm track width. Its a drop down menu so just select the width you want.
Then click on a pad on a part where you want to start to route from. Eagle will draw the track and follow your mouse movements with the track..
- R1.JPG (136.02 KiB) Viewed 4853 times
Now if we right click, we can change the angles/bends of the track routed to something which routes a little nicer.
- R2.JPG (138.58 KiB) Viewed 4853 times
We then can move to the left and click the destination pad and the track is done.
Now route all the other tracks and make them look as nice as you can...
- R3.JPG (125.88 KiB) Viewed 4853 times
We have a wire on JP1 (right pad) which doesn't look so easy to route.
So option 1 , is to select a smaller track width. In this case I use 0.254mm and route it like below...
- R4.JPG (128.29 KiB) Viewed 4853 times
But wait, I changed my mind and I don't want to do it like that anymore. So lets complicate it even more.. That's the way I roll sometimes
Use the RIPUP tool... Then click the track we just created and delete it.
TIP: Eagle will only delete one particular section of a track, not the whole lot. So you may need to click the track in multiple places to remove it.
NOTE: Double clicking traces will remove ALL signals connected to it. So if you double click on the GND signal for example, it will rip up the whole lot. This probably isn't what you want to do right now, so don't do it. Unless you want to cause yourself pain, in which case go right ahead
- R5.JPG (129.01 KiB) Viewed 4853 times
So we should be back to this.. with our "air wire" which is the un-routed track once again.
- R6.JPG (120.13 KiB) Viewed 4853 times
So lets try routing the signal on the bottom of the PCB instead.
We click the LAYER menu and select TOP layer.
- R7.JPG (137.7 KiB) Viewed 4853 times
Now when you click on the right pad of JP1, Eagle will route on the TOP layer. All signals connected to it (in this case GND) will be highlighted.
NOTE: Mine highlights in yellow (its how I set it up and may not be the same colour for you )
- R8.JPG (127.18 KiB) Viewed 4853 times
So route the signal like below. Right click away if you need to change angles of the track.
- R9.JPG (128.93 KiB) Viewed 4853 times
Now lets zoom out so we can see the outer white box (dimension border).
Use the MOVE tool and move the box lines one at a time so it looks something like below.
This will be the overall dimensions of the PCB when (eventually) goes to the PCB house.
TIP: Always leave a little room around the outside of the PCB otherwise you could run the risk of parts being chopped off etc. Bare in mind though, larger PCB's are more expensive, so leave a little space around the edges, but don't be silly about it
- DI1.JPG (127.93 KiB) Viewed 4853 times
