Pak86/3 Tos Roms
Upgrade or replace the ROM.
Pak86/3 Tos Roms
Hi All,
I'm just building an 030 Pak86/3 but havent been able to locate the patched TOS Rom, does anyone know where I might locate this? Apparently its 3.06 patched for the PAK.
Re: Pak86/3 Tos Roms
RJ was collecting this stuff, but AFAIK there isn't any 030 stuff... might be worth a look though...
https://www.exxosforum.co.uk/forum/viewt ... f=38&t=635
That was the Pak020 stuff, already got one of them, wanted an 030 to play with :)
Maeke
Post by Maeke »
Good luck with that, i wasn't even able to find the schematics...
If i take too long to reply, sorry my cat is sleeping on my laps.
Maeke wrote: Fri Nov 16, 2018 9:24 pm Good luck with that, i wasn't even able to find the schematics...
You can find most of it here:
http://www.wrsonline.de/pak3.html
Maeke
Post by Maeke »
I've already looked several times into this site, for nothing, those aren't the schematics of the pak68/3, only the layout.
Darklord
Post by Darklord »
Umm, I've got the files needed to burn your own TOS v3.06 ROMs adapted for the
Pak 68/3 board. Holger Zimmerman was kind enough to do an English version for
me.
HTHs.
306USPAK.zip
(555.47 KiB) Downloaded 309 times
Here are the files for the chips on the board itself.
PAK GALs.zip
(5.76 KiB) Downloaded 330 times
This is my board, installed in my STacy. Note it is actually running at 40mhz, not the 32mhz
oscillator chip shown.
Thanks Darklord, got some Roms to burn this weekend then see what happens :D
Darklord
Post by Darklord »
You are most welcome.
Love to see more Pak boards in play - they are really
well engineered.
Hi Darklord,
I don't suppose you have a schematic for this version of the Pak do you? Mine's not working so far but think it's a problem with my Atari, just wanted to rule it out.
Return to “ROM UPGRADES”
