TerribleFire 328/330 Support (CD32)
Hi folks,
This thread is for TF330/328 support. Pretty much @supaduper knows everything there is to know about the TF328. So he can help out. If you really want bare 328 boards i sell em on ebay with the logo. I recommend just paying supaduper to build you one.
As i build the first 330 i'll post pictures here.
8 Bit Dreams
Re: TerribleFire 328/330 Support (CD32)
Post by 8 Bit Dreams »
Much appreciated TF3xx series got separate thread, will be easier to find information needed now..
Also please check Wiki:
https://github.com/terriblefire/tf328/wiki
nils
Post by nils »
you asked in your Nov 11 youtube post if people would like to see the TF330.. yes I would
I recently just got the tf328 and a riser for my cd32 that was sitting for years been having lots of fun with it worth it, only found it by accident looking around on ebay
I think if the TF330 I'd snap one up right away too, although I'd have to someone build it for me my eyesight isn't that good to work on small things even with a magnifying glass
nils
alenppc
Post by alenppc »
nils, if you're one of those who bought the card from me, thank you. The TF330 will most likely be available from the same people that are building the rest of Stephen's cards, such as 8 bit dreams, supaduper and me.
The biggest challenge here will be securing a good supply of 68030 CPUs. I want to try and keep the prices as low as possible before certain resellers try to make a quick buck on them as we've seen happen from time to time ;-)
I had found a good source of CPUs for the TF530 run but now that one has been exhausted...
alenppc wrote: Wed Nov 14, 2018 6:21 pm nils, if you're one of those who bought the card from me, thank you. The TF330 will most likely be available from the same people that are building the rest of Stephen's cards, such as 8 bit dreams, supaduper and me.
There are hundreds available on ebay. The MC68030RP33B is the way to go. they run at 50Mhz fine from what i can tell.
nils
Post by nils »
I wasn't able to send a private msg so please keep me updated when you have something going
I will need to find a place to recap the CD32(I should do it before it has a problem it appears to be fine right now) and an Amiga 4000 MB(the 4000 needs a trace repaired at one of the caps)
nils
alenppc
Post by alenppc »
Get your CD32 recapped even if it seems fine, chances are the old caps are already leaking merrily all over the board. The PAL units are particularly problematic as they have 2 caps factory mounted backwards (not the case with NTSC units). Where are you located?
thairacer
Post by thairacer »
:D Hi steven, Hi supaduper ! funny to comes in a Atari forum (but i started my life with a 520 STF) , Amazing card , so happy , i already have the stunning TF328 sent by Supaduper, stay tunned and Amiga is Alive and Kicking ! i bought the CD32 in 1993 against the advice of my friends who went to PSX or PC, solded 6 months after cause no real CD32 game and bought again in 2015 ! so happy with it .
nils
Post by nils »
alainppc mine is an NTSC unit I'm in Canada I can dissemble it(cd32)so I can send just the motherboard someplace, I have the 4000's MB out of the case already too.
alenppc
Post by alenppc »
nils wrote: Sun Nov 18, 2018 12:36 am alainppc mine is an NTSC unit I'm in Canada I can dissemble it(cd32)so I can send just the motherboard someplace, I have the 4000's MB out of the case already too.
That's perfect, I can recap it for you, you can contact me by email, use the same nickname at gmail. Thanks.
