- IMG_3357.JPG (6.7 MiB) Viewed 8395 times
- IMG_3358.JPG (6.26 MiB) Viewed 8395 times
- IMG_3359.JPG (5.96 MiB) Viewed 8395 times
- IMG_3360.JPG (7.15 MiB) Viewed 8395 times
Its not something I have tried or documented on the STM. I suggest not changing them unless you have issues.HCRX27 wrote: Mon Sep 15, 2025 7:47 am Dear Exxos,
there's no information on bus-resistors replacement for that exact motherboard (C070243 REV.H):
viewtopic.php?f=17&t=2235#p27504
Could you please advise if all of them can be safely replaced with 2.2kOhm? There are 6 of them, if I see it right.
I'm not aware of any issues no. I'm sure others have changed them without issue.HCRX27 wrote: Mon Sep 15, 2025 9:08 am There are issues with loading HD adapted games from SidecarT or IDE HDD after I replaced CPU to 68HC000 in HyperCache turbo (16MHz + cache), because the NMOS wanted to burn the keyboard above it aliveLoading from Ultrasatan with no SidecarT attached is working fine, though, with good overall stability.
So I guess, replacing them all with 2.2kOhm should do no harm either for HC or if I stay with NMOS?
