Megafile 30 bites the bullet
So my Megafile 30 HDD made a grinding noise this morning and now stopped spinning :cry:
I know trying to replace a MFM / RLL drive is a non-starter so am looking to see what the best option is.
Just throwing out a few suggestions and am open to others.
  • Replace everything inside with something like a Gigafile or UltraSATAN but keeping the ACSI in and out ports
  • Replace with a ACSI to SCSI convertor and a SCSI HDD to provide the a similar disk like sound
sandord
Re: Megafile 30 bites the bullet
Post by sandord »
I'm sorry to hear that your precious drive has died!
Icky wrote: Sat Oct 20, 2018 11:40 am Replace with a ACSI to SCSI convertor and a SCSI HDD to provide the a similar disk like sound
Perhaps you could go with the UltraSatan and keep the/a drive in there as well for the sounds. I would require some trickery, probably using an arduino or something to trigger the drive heads. Think of the famous disks drive music projects like:
I know, this wouldn't be a small project :roll:
I do have a similar hard drive in the for sale section if that helps..
PaulJ
Post by PaulJ »
I put a scsi2sd 5.1 board in my mega-set. It works reliably but its not as fast as the Ultra Satan. It tested out at 720 kb /sec while the Ultra Satan was running at 1000 kb/sec.
https://www.ebay.com/itm/SCSI2SD-v5-1-b ... :rk:1:pf:0
PaulJ wrote: Sat Oct 20, 2018 3:18 pm I put a scsi2sd 5.1 board in my mega-set. It works reliably but its not as fast as the Ultra Satan. It tested out at 720 kb /sec while the Ultra Satan was running at 1000 kb/sec.
Thanks Paul - interesting to see Ultrasatan is faster. Might be swaying to that direction.
PaulJ
Post by PaulJ »
Yes, its 30% faster..
Well I have given up on the Megafile. I don't have the time to play around with it.
So if anyone wants it they can have it £0 - just need to pay the postage costs.
PaulJ
Post by PaulJ »
Icky wrote: Fri Nov 16, 2018 12:34 pm Well I have given up on the Megafile. I don't have the time to play around with it.
You can keep your extra glitter in it.
PaulJ wrote: Fri Nov 16, 2018 2:38 pm
I would accept your offer but I'm busy trying to devlutter as it is :shock:
