Using stock TT 16 Med as the benchmark comparison.
TT 10mb STRAM 64mb TTRAM Storm ATI Mach64 with NVDI 1280x1024 256col
Re: TT 10mb STRAM 64mb TTRAM Storm ATI Mach64 with NVDI 1280x1024 256col
What sort of RAM are you using in your Storm? Does it have fast page mode enabled?
Ah yes sorry, forgot to say. I am using Kingston ram with FPM and EDO burst enabled.
Snap:
Same config but with 256MB Ram and FPU overclock
Question - does your TT have the VME patch?
I spoke to Atarian Computing (josh) and he thinks mine has the vme patch done on the pcb in the factory. I implemented a fix where the factory oscillator mod was incorrect, following Josh's instructions, everything seems to work well.
- frank.lukas
Atari Mega ST1 with 4MB ST Ram, 8Mhz Board Clock, PAK68/3 with 68030-50Mhz /68882-50Mhz -32kB L2 Cache, FRAK/2 with 64MB TT Fastram, Panther/2 with NE2000 ISA Ethernet card (MiNT Driver) and a ATI MACH32 2MB ISA Videocard.
To Speedup I looking for a MACH64 ISA Graphiccard and set up the Boardclock to 10,12 or 16Mhz ...
