So, after programming the GAL (thanks
@exxos,
@Icky and
@kodak80), pin 14 in the GAL does output 8MHz:
- pic_42_1.jpg (82.11 KiB) Viewed 5975 times
But, floppy in 720k mode did not work.
Then, I connected pin 2 of the Gotek to the bottom pin of JP18 (as suggested in
viewtopic.php?f=78&t=2551&hilit=gal+programming#p33807 ), but also did not work.
(with "did not work", in all cases, I mean the drive does not make seek sounds and, when trying to open the drive in TOS 2.06, I get the message "Data on the disk in drive A: may be damaged.")
I just wanted to verify something:
@kodak80, reading your post mentioned above, in the section about automating the selection of 720 or 1.44 modes, it says:
JP22 has pins 2 and 3 connected so that the 1.44mb IC controls the clock speed to the WD1772.
Are the pins in JP22 different in the H4 board than the H5? Because in the label of the H5 B1 board, it says pins 2&3 are for "8MHz 1772" and 1&2 are for "8MHz & 16 MHz GAL mode". So, it seems to be opposite of what's described in the post, right?
In any case, I tried JP22 in both 1&2 and 2&3, and the Gotek still does not work.
