ACORN A5000 inbound
Re: ACORN A5000 inbound
HigashiJun wrote: Thu Nov 30, 2023 10:31 am
rubber_jonnie wrote: Thu Nov 30, 2023 10:23 am Don't forget the IDE supports a limited number of drives unless you use something like Wizzo, mine is just a 128MB IDE flash drive, I use SCSI for most stuff.
You'll need !hform IIRC to prep any IDE drives you want to use.
Yes, the onboard IDE is somehow limitated...
I plan to get myself a ZIDEFS IDE, and I already have the special !hform.
Good stuff. Do you have the mouse yet? If so can you open and run the Apps? You probably already know, but if you hit right CTRL + Right SHIFT and F12 it will go into shutdown mode.
HigashiJun
Post by HigashiJun »
rubber_jonnie wrote: Thu Nov 30, 2023 10:54 am Good stuff. Do you have the mouse yet? If so can you open and run the Apps? You probably already know, but if you hit right CTRL + Right SHIFT and F12 it will go into shutdown mode.
The mouse was released from the customs and should reach me tomorrow if I'm lucky.
Yes, I know this key combination. Very useful indeed.
HigashiJun wrote: Thu Nov 30, 2023 11:06 am
HigashiJun
Thought I had finished all the traces repair today:
One on the side.
Two on the backside of the motherboard...
And two from the 74HCT245T buffer
but I realised that there is no continuity here (see the red circle):
I need a smaller solder tip to perform this repair, and if it doesn't work, then I will have to de-solder the connector...
The tip is already ordered on Amazon and should be delivered soon, so I will be silent for 2 or 3 days.
I feel really bad for all my previous repairs now and want to do them all like yours, they are so neat, I love it.
HigashiJun
@rubber_jonnie
Thanks you very much.
I always try to do the best I can, for me and even for others in case I plan to sell my machines.
What would you prefer to buy ? A retro computer with crap repairs or something decently fixed ?
I opt for the second solution.
Even if it takes more time, I think these old machines deserve it.
HigashiJun wrote: Fri Dec 01, 2023 11:24 am @rubber_jonnie
For me it has so far been about making things work, as I am a little 'clunky' so fine work is a bit harder, but I am trying to improve as it increases satisfaction levels when you fix or mod something beautifully :)
I admit that I just use bodge wires between the end targets of the traces. At least that shows where the fixes have been made.
Given that manufacturers used the same techniques in production for hot fixes to PCBs I don't see that it's a shortcut or messy.
HigashiJun
rubber_jonnie wrote: Fri Dec 01, 2023 11:31 am ..., but I am trying to improve as it increases satisfaction levels when you fix or mod something beautifully :)
Yup, I totally agree.
8-)
HigashiJun
stephen_usher wrote: Fri Dec 01, 2023 11:46 am I admit that I just use bodge wires between the end targets of the traces. At least that shows where the fixes have been made.
I also like the visual aspect of such repairs, that's why aesthetics matters for me.
Bodge wires can also look nice, but it depends on how they are routed.
