PiStorm Chat
Re: PiStorm Chat
alexh wrote: Wed Jul 13, 2022 11:35 pm Nice. How did you fix processors that have more than 24 address bits?
The emulator was refusing to attempt to pass through any addresses with the top byte set. Of course we know that 0xFFnnnnnn needs to map to 0x00nnnnnn, so I put in a translation for that before the top byte check*.
Not efficient, needs to be moved to platform specific code at some point, but good enough to show them working.
No further speed gain once we get to the 020, but it's nice to have an STE with a full 040 processor and 516MB of RAM. :lol:
* EmuTOS makes extensive use of 0xFFFFnnnn registers before any MMU is set up. I presume this is deliberate and expected to be handled in hardware.
Re: PiStorm Chat
OK, so after some truly heinous hacking, a *partially* working bus error emulation seems to have fallen out.
PiStormST can now boot from stock OS images. Here's 2.06 doing its thing.
Next step will be to try to understand what's going on and tidy this whole thing up. Then it'll be looking into why ST-RAM accesses are so slow. My gut feeling is it's protocol limitations, but we'll see.
There's an alternative asynchronous firmware called PiStormX which I fancy is worth looking at. Ties in better with how I approach bus cycles in my other firmwares.
Cheers,
BW.
agranlund
Re: PiStorm Chat
Post by agranlund »
Badwolf wrote: Fri Jul 22, 2022 12:30 pm OK, so after some truly heinous hacking, a *partially* working bus error emulation seems to have fallen out.
Awesome progress!!
Cyprian
Re: PiStorm Chat
Post by Cyprian »
great
http://260ste.atari.org
Re: PiStorm Chat
Treating the symptom rather than the cause, but stability greatly improved by a late-in-the-day check for IPL mismatch.
The issue I was seeing repeatedly was that the interrupt acknowledge cycle was often generating a bus error because there was no actual interrupt to acknowledge!
The IRQ system in PiStorm is very opaque and any change to what often appear magic numbers causes it all to fall apart. So I've kind of admitted defeat for now and implemented this check. I still have seen a couple of errors, but things are better.
The big issue is still bus access speed. Unfortunately the gap between bus cycles is too large. One cycle to the next is ~1us whereas on a proper 8MHz 68000 it's ~500ns. Hence I'm seeing 50% speed (the figures above should be 3.7MB/s).
There are two contributory factors to this. Firstly turning on bus (and address) errors costs time. Secondly, the Amiga asserts it data earlier in the cycle meaning PiStorm can normally just abandon the cycle early, meaning the cycle-to-cycle time comes down. We can't on the ST as data is only asserted at the 'correct' time, meaning we have to go through a full three-clock bus cycle.
Of course, turning on the features -- TT-RAM, 020 processor, virtual ROM, mitigates this to some extent on OS-based apps (see below), but the RAM speed still never gets above 57%.
I might have to learn how to do profiling on a multithreaded linux app to know where to go next.
Re: PiStorm Chat
That sounds all rather painful!
Re: PiStorm Chat
If you think that it is related to the performance of the software can you prove this by over clocking (or under clocking) your Pi?
Re: PiStorm Chat
alexh wrote: Wed Aug 03, 2022 9:47 am If you think that it can be solved by increasing performance of the software can you prove this by over clocking your Pi?
I don't think the RPi3 supports overclocking and, if I had to guess, I'd say it's unlikely we can bridge that gap as things stand.
That said, it's an untested theory ATM. Finding out a way to log the cycle-to-cycle times when using 'virtual' memory (eg. pi-based TT-RAM) would give us more evidence.
The fact that emulated TT-RAM was only clocking similar figures to DFB1 (and lower than TF536) in my screenshot above when internal RAM accesses are effectively instant does suggest to me a fundemental bottleneck in the emulation ATM.
Emu68 (the bare metal software for PiStorm) might be the alternative to circumventing this. It does have the downside that nice to have features like network and RTC become orders of magnitude harder, though (drivers have to be written on *both* sides of the PiStorm board).
Re: PiStorm Chat
Badwolf wrote: Wed Aug 03, 2022 9:54 am
Yes? I was sure it did, but maybe not. Perhaps turn off "turbo"?
Badwolf wrote: Wed Aug 03, 2022 9:54 am if I had to guess, I'd say it's unlikely we can bridge that gap as things stand.
I wasn't suggesting overclocking as a fix, more..... if extra/fewer CPU cycles improves/degrades performance then you can look to optimise the code. If it doesn't then maybe it is latency in the Pi<->CPLD interface which is independent of emulation performance?
Badwolf wrote: Wed Aug 03, 2022 9:54 am The fact that emulated TT-RAM was only clocking similar figures to DFB1 (and lower than TF536) in my screenshot above when internal RAM accesses are effectively instant does suggest to me a fundemental bottleneck in the emulation ATM.
TF536 uses SDR DRAM? Could it be the Pi's DDR3 latency? DDR3's higher latency is usually compensated for with CPU caches etc. But if the emulation is doing somehow doing something which negates the effect of the cache then it might have an effect? Probably not but I thought I'd throw it out there.
Re: PiStorm Chat
alexh wrote: Wed Aug 03, 2022 12:05 pm Perhaps turn off "turbo"?
Can try that as an experiment, but the cycles are quite quantised, so it would need a big change to make any noticiable difference, I suspect.
I wasn't referring to overclocking. I suspect it's unlikely we'll find a 2x speed gain via any cumulative mechanism, unless I have a real head-slap moment and find a silly mistake.
