TF536 on A2000
68030 + SDRAM + IDE
Re: TF536 on A2000
No this will be a clock phase issue.. 99% likely. Just not in a position to test on the A2000 right now.
matt020
Re: TF536 on A2000
Post by matt020 »
Is a clock phase issue fixed with firmware or by hardware changes?
GadgetUK164
Re: TF536 on A2000
Post by GadgetUK164 »
matt020 wrote: Fri Jul 17, 2020 12:16 pm Is a clock phase issue fixed with firmware or by hardware changes?
You will need to rebuild your board, then your amiga, followed by your entire house! :o) Very probably a firmware change can fix it!
8 Bit Dreams
Re: TF536 on A2000
Post by 8 Bit Dreams »
GadgetUK164 wrote: Fri Jul 17, 2020 9:48 am Is it possible the SMD component sizes fitted by the PCB manufacturer are the wrong size or something (on the underside). eg. resistor arrays, resistors.
Nope..
Ive took bare boards and soldered them manually..
Re: TF536 on A2000
The phase on the r1 A2000 version was 5.
alenppc
Re: TF536 on A2000
Post by alenppc »
Mine are all flashed with phase7
Re: TF536 on A2000
Give this a go.. i'm not near a machine so i cant test anything...
tf536r2_2020_07_17_alpha.zip
(17.17 KiB) Downloaded 211 times
Dont ship this out to anyone please.... its an experiment.
ericgla
Re: TF536 on A2000
Post by ericgla »
I only had a few minutes to test before I have to pick up my kids...
Flashed using tf536r2_main_top_AMIGA_FULL_PHASE_5.jed
No change. Same purple screen in DiagROM on boot.
alenppc
Re: TF536 on A2000
Post by alenppc »
Works on the A500. The only difference that I can see is that the ESM no longer reboots the machine upon a keypress. The rest seems pretty much the same.
Re: TF536 on A2000
Ok try a scope probe or finger on the motherboard DTACK pin.
Return to “TF536”
