TF536 on A2000
- Admin sponsor
Re: TF536 on A2000
No this will be a clock phase issue.. 99% likely. Just not in a position to test on the A2000 right now.
Re: TF536 on A2000
Is a clock phase issue fixed with firmware or by hardware changes?
- GadgetUK164
Re: TF536 on A2000
You will need to rebuild your board, then your amiga, followed by your entire house!matt020 wrote: Fri Jul 17, 2020 12:16 pm Is a clock phase issue fixed with firmware or by hardware changes?
- 8 Bit Dreams
- Moderator Team
Re: TF536 on A2000
Nope..GadgetUK164 wrote: Fri Jul 17, 2020 9:48 am Is it possible the SMD component sizes fitted by the PCB manufacturer are the wrong size or something (on the underside). eg. resistor arrays, resistors.
Ive took bare boards and soldered them manually..
- Admin sponsor
Re: TF536 on A2000
The phase on the r1 A2000 version was 5.
Re: TF536 on A2000
Mine are all flashed with phase7
- Admin sponsor
Re: TF536 on A2000
Give this a go.. i'm not near a machine so i cant test anything...
Dont ship this out to anyone please.... its an experiment.
Re: TF536 on A2000
I only had a few minutes to test before I have to pick up my kids...
Flashed using tf536r2_main_top_AMIGA_FULL_PHASE_5.jed
No change. Same purple screen in DiagROM on boot.
Re: TF536 on A2000
Works on the A500. The only difference that I can see is that the ESM no longer reboots the machine upon a keypress. The rest seems pretty much the same.
- Admin sponsor
Re: TF536 on A2000
Ok try a scope probe or finger on the motherboard DTACK pin.
