since mp3 are usually stored on hdd..
TF CD32 Riser Revision 2 Design Complete
- 8 Bit Dreams
- Moderator Team
Re: TF CD32 Riser Revision 2 Design Complete
Well..this will need quick ide access,
- arkadiusz.makarenko
- Moderator Team
For mp3 it would need to be 16-24KB per second.8 Bit Dreams wrote: Sun Nov 29, 2020 10:18 pm Well..this will need quick ide access,
since mp3 are usually stored on hdd..![]()
With current theoretical setup (not measued though) I think we should be able to get about 1MB/s (1 Byte per microsecond
Edit
So question is how much slowdown hdd would introduce. IMHO for mp3 we have enough margin.
Edit2:
Plus availability of fastram, where data can be preloaded
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Rubbish. MP3 is way more compressed than CD audio and that works with x1 CD Speed. You can do MP3 over a bit banged serial on a parallel port on an Amiga 500.8 Bit Dreams wrote: Sun Nov 29, 2020 10:18 pm Well..this will need quick ide access,
Yeah, I can listen to uncompressed wav on my CD32 streaming from CF card no problem.terriblefire wrote: Mon Nov 30, 2020 10:38 amRubbish. MP3 is way more compressed than CD audio and that works with x1 CD Speed. You can do MP3 over a bit banged serial on a parallel port on an Amiga 500.8 Bit Dreams wrote: Sun Nov 29, 2020 10:18 pm Well..this will need quick ide access,
- Admin sponsor
Absolutely top end MP3 is only 320 kbps. small B.wairnair wrote: Mon Nov 30, 2020 10:58 am Yeah, I can listen to uncompressed wav on my CD32 streaming from CF card no problem.
The CD32 serial port can almost do that.
- 8 Bit Dreams
- Moderator Team
Thank You Sir,
This gives a good hope to run Mp3's or listen Internet radio!
- Moderator Team
@terriblefire
Is there a standard for communication on those cards at all, or are they have proprietary drivers?
Do we have anything to start looking at?
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
The best source of information will be WinUAE sources.arkadiusz.makarenko wrote: Mon Nov 30, 2020 8:29 pm @terriblefire
The Prelude 1200 is probably the best choice but i've only spent 10 mins thinking about it.. We dont want to do be doing DSP in the ARM.. thats too much work for it.
The prelude 1200 has a Crystal Semiconductor Sound Codec 4231A chip in it ... datasheet
There will be code in WinUAE to show how its mapped in memory.. but thats the simplest candidate for a soundcard?
- Moderator Team
Thank you, I will try to get my head round it.terriblefire wrote: Mon Nov 30, 2020 10:55 pmThe best source of information will be WinUAE sources.arkadiusz.makarenko wrote: Mon Nov 30, 2020 8:29 pm @terriblefire
The prelude 1200 has a Crystal Semiconductor Sound Codec 4231A chip in it ... datasheet CS4231A_ETC.pdf
I think before I start doing anything more I need to refactor keyboard routine. It has large sections of blocking code. If there was any more intensive processing needed done in main loop, then those delays might slow down things.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Yeah i'd finish what we have in flight first...
For the Audio.. i might even assume that data that comes in on a particular address "SPARE_CS" on the clockport is an MP3 Stream...
