PiStorm Chat
Re: PiStorm Chat
dad664npc wrote: Fri Apr 12, 2024 10:42 am I don't use a fan, however, my Pi stands vertically.
There aren't many of us using PiStorm to be fair, and every setup seems to be different, meaning there is no defacto setup.
That be first problem, Really I need to rule out any thermal type problems.
Seems there are things like this.
https://www.ebay.co.uk/itm/404915219471
But of course would render the idea of removing the sockets little bit pointless then.. But I would much rather limit external factors such as overheating particulars I would plan on running it all day for testing stuff out.
dad664npc
Re: PiStorm Chat
Post by dad664npc »
exxos wrote: Fri Apr 12, 2024 10:47 am
Let me do some quick testing with another pi4 without heatsink
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
dad664npc
Re: PiStorm Chat
Post by dad664npc »
15 minutes of running BW's Elite FrontBench - configured as a 68020
Temperature is fluctuating between 43 and 46C
Using HDMI for et4000 emulation, then temperature increases to 54C
Of course running for longer will likely creep up, but these temperatures are a long way off thermal maximums
Re: PiStorm Chat
Thanks, I guess just a couple a small stick on things will probably do then. I can keep an eye on temperatures when it's running and worry about it another time.
mrbombermillzy
Re: PiStorm Chat
Post by mrbombermillzy »
I didnt realise the later Pis needed at least passive cooling. :(
Are we starting to enter the era of having to engineer RPi cooling solutions and proper ventilation in our Atari cases to deter heat related issues/lockups?
Re: PiStorm Chat
dad664npc wrote: Sun Apr 14, 2024 4:34 am PiStorm already works on WiFi.
There is a way to mount a disk image for the emulator and files can be copied back and forth (between the Pi file system and Atari live) - it is experimental of course.
That sounds cool. Not sure how that works overall. I think cosmosex could mount a gem drive which is mapped to a pc folder. That was useful as saved using floppies and SD cards etc.
Re: PiStorm Chat
Just for your benefit @exxos here is how I've mounted mine in my H5
Re: PiStorm Chat
exxos wrote: Sun Apr 14, 2024 12:05 pm
The disk image I'm preparing for you will have all that enabled by default. I'll have it ready soon.
Re: PiStorm Chat
Thanks. I wonder if the pi can be flipped upside down and placed over the other 68k socket. Probably makes no odds really.
Steve wrote: Sun Apr 14, 2024 5:37 pm The disk image I'm preparing for you will have all that enabled by default. I'll have it ready soon.
Thanks no rush. Still waiting for goose to reply yet.
Re: PiStorm Chat
So @go0se replied and he said he only makes them with 74LVC16373ADGG and not heard of the 374s working better.
So I'm in a bit of a non starter here then it seems if nobody is making them with 374s :shrug:
