TFMSX Arrives
- arkadiusz.makarenko
- Moderator Team
Re: TFMSX Arrives
I understand now.
For Port C and SPI I think 1 jumper wire for SPI Clock might be needed as I can't find SPI CLK on Port C.
I will dig out docs, maybe it is on alternative pin configuration.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Re: TFMSX Arrives
A couple of patch wires will be fine.. This board has let me figure out all the nasty issues with clocks and understand how to do slot expanders. Its been a useful exercise. I'm betting not everthing is working but Knightmare and Monkey Acc work fine.arkadiusz.makarenko wrote: Mon Apr 19, 2021 9:33 am I understand now.
- Moderator Team
Re: TFMSX Arrives
SPI2 can have MOSI on (transmit only mode) on Pin 9, 11 or PB15 (used by USB)
and CLK on Pin 42, 34 or 28.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Re: TFMSX Arrives
9 is already connected so we can use that... do you have a preference for CLK? Also are there options for CS_N?arkadiusz.makarenko wrote: Mon Apr 19, 2021 2:29 pm SPI2 can have MOSI on (transmit only mode) on Pin 9, 11 or PB15 (used by USB)
- Moderator Team
Re: TFMSX Arrives
There is option for hardware NSS signal for Input/Output on pins 62, 56 or 33.
I guess default would be best as in the past there were minor issues with alternative configurations on some chips (most likely not anymore).
So SPI2 default pins would be this
SPI2_MOSI PC1 pin9
SPI2_SCK PB10 pin28
SPI2_NSS PB12 pin 33
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Re: TFMSX Arrives
Right we'll go with that .. the 4 "row scan pins" that you read as inputs can be on any of the other connected pins..arkadiusz.makarenko wrote: Mon Apr 19, 2021 6:23 pm There is option for hardware NSS signal for Input/Output on pins 62, 56 or 33.
So SPI2 default pins would be thisCode: Select all
SPI2_MOSI PC1 pin9 SPI2_SCK PB10 pin28 SPI2_NSS PB12 pin 33
- Admin sponsor
Re: TFMSX Arrives
@arkadiusz.makarenko Do you have a spectrum / amstrad RGB scart cable? i've rewired the DIN plug i have to support that video pinout
- Moderator Team
Re: TFMSX Arrives
I have full set of +2 cables, composite and RGBs.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Re: TFMSX Arrives
Sweet.. i'll post you build #2 of the TFMSeX before friday...arkadiusz.makarenko wrote: Mon Apr 19, 2021 9:45 pm I have full set of +2 cables, composite and RGBs.
- Admin sponsor
Re: TFMSX Arrives
Next project is to get the MSX2 roms booting.
