PiStorm Chat
Re: PiStorm Chat
exxos wrote: Wed Apr 10, 2024 7:10 pm
Steve wrote: Wed Apr 10, 2024 7:08 pm @exxos Yeah that'd be great :) Remember to get that GPIO riser package I mentioned in PM too.
Was just looking at that, looks like the connectors I use on my Falcon RAM boards, no idea if the pitch is the same though, think the falcon was 2mm pitch..
I think the GPIO is 2.54mm pitch: https://www.google.com/search?client=fi ... gpio+pitch
Re: PiStorm Chat
Yep, normal 2.54mm so that you can use normal Dupont connectors.
Re: PiStorm Chat
Cool, my falcon ones won't fit then, I will order one off amazon or somewhere then. Shame rapid don't seem to sell them.
Isn't this is ?
https://www.rapidonline.com/pimoroni-pi ... ns-75-0810
mrbombermillzy
Re: PiStorm Chat
Post by mrbombermillzy »
Steve wrote: Wed Apr 10, 2024 7:08 pm Remember to get that GPIO riser package I mentioned in PM too.
Hang on. Just to clarify, Im sure I asked @Badwolf about using a Pi3B for this (using a riser because of the double stacked USB ports on the 3B) and Im sure I was warned by him not to use a GPIO riser because of signal degradation issues.
Re: PiStorm Chat
I've ordered the 2 things from Rapid. Just need to source the IO board now. But a bit puzzled why it has a PLD on it @Steve ?
Edit:
Ok a quick look at the code and seems to do some 030 to 68k type interfacing. I would have thought all that would have been done in the pi though. Seems a bit messy like running a emulator on top of another emulator :shrug:
Re: PiStorm Chat
Some things will be timing critical that the Pi won't be able to do quickly enough, so you need a simpler and deterministic device.
dad664npc
Re: PiStorm Chat
Post by dad664npc »
exxos wrote: Wed Apr 10, 2024 9:28 pm I've ordered the 2 things from Rapid. Just need to source the IO board now. But a bit puzzled why it has a PLD on it @Steve ?
Edit:
Make sure you get yourself a PiStorm with 374 latches
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
Re: PiStorm Chat
dad664npc wrote: Thu Apr 11, 2024 4:02 am Make sure you get yourself a PiStorm with 374 latches
:2k2:
What was the reason for that over 373 ?
dad664npc
Re: PiStorm Chat
Post by dad664npc »
exxos wrote: Thu Apr 11, 2024 9:35 am What was the reason for that over 373 ?
Timings - some ATARI's work, some don't - you know all about that :)
Re: PiStorm Chat
dad664npc wrote: Thu Apr 11, 2024 9:37 am Timings - some ATARI's work, some don't - you know all about that :)
Ah yep. I better stock up on Vodka again then.
