PiStorm Chat
Re: PiStorm Chat
Cyprian wrote: Fri Oct 06, 2023 8:38 am STE:
I should point out this board is very much in the alpha-testing phase ATM. We're not 100% sure it's fully reproducing the performace of its DIP bretheren.
Re: PiStorm Chat
Badwolf wrote: Fri Oct 06, 2023 11:33 am If I had to guess, therefore, I'd guess the simple option were taken so it's unlikely to work on an STE with a soldered chip.
The way my switcher does it is to assert the HALT line on the CPU which you want disabled. This not only halts the CPU but the CPU also tristates its outputs.
Re: PiStorm Chat
stephen_usher wrote: Fri Oct 06, 2023 11:58 am The way my switcher does it is to assert the HALT line on the CPU which you want disabled. This not only halts the CPU but the CPU also tristates its outputs.
IIRC HALT doesn't tristate the control lines, you need BGK for proper quiescence.
Re: PiStorm Chat
OK, fair enough. The next rev, if there ever is one, will have to do that.
ijor
Re: PiStorm Chat
Post by ijor »
Badwolf wrote: Fri Oct 06, 2023 12:00 pm
There is no way to completely disable a CPU without, at least, disconnecting some pins. Some signals are never tristated by the CPU, not even on reset, halt or with the bus relinquished.
http://pasti.fxatari.com
Darklord
Re: PiStorm Chat
Post by Darklord »
dad664npc wrote: Fri Oct 06, 2023 7:37 am PiStorm works in both ST and STe
STe requires an adaptor board - DIL to PLCC
Mint is not required
Any Pi4 model B will work
Pi3A+ is shown to work
badwolf has shown that the latch type no longer matters
I have never seen a STacy in person, but from images, it seems compact. I very much doubt you could install a PiStorm and run it encased - but am happy to be told otherwise
Thanks for the info, appreciated.
As far as my STacy goes, I have a Pak 68/3 board sitting in there right now. Derkom has a TF board in his STacy.
I'm assuming (from the pictures) that the ST version of the PiSTorm is smaller than these boards. Is that correct?
Thanks again (and thanks to everyone for all the hard work on this project and supporting the Atari community) :!:
PICO PS01.JPG (273.36 KiB) Viewed 1754 times
Re: PiStorm Chat
Darklord wrote: Fri Oct 06, 2023 4:22 pm I'm assuming (from the pictures) that the ST version of the PiSTorm is smaller than these boards. Is that correct?
It'd be taller than the TF536, even with Derkom's relocator board. You'd still need to relocate it so it would be three boards stacked rather than two.
You could save horizontal space by using a Pi Zero 2 instead of a full 3+, overclock it to 1.4GHz and fit a fan. It may be slightly shorter.
Darklord
Re: PiStorm Chat
Post by Darklord »
stephen_usher wrote: Fri Oct 06, 2023 4:39 pm
Ah, and there might be the problem. You have a little bit of space horizontally to play around with, in the STacy but not much
vertical space to use at all...
So it's the PiSTorm board itself, the Pi4 (or whatever version) and then...what is the 3rd board if it's not an STe? Thanks! :)
dad664npc
Re: PiStorm Chat
Post by dad664npc »
If you are wanting to install PiStorm using DIL socket, then there are two boards - the lower of the two, is the PiStorm board itself. On top of that sits the Raspberry Pi.
If you are using a Pi3A+ then that yields the lowest profile. If you are wanting to fit a Pi4, then because of the extra I/O (Ethernet/USB ports), then a GPIO header extender is needed, which raises the profile by another 8mm
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
Darklord
Re: PiStorm Chat
Post by Darklord »
Thanks for the info.
Has anyone actually put one in an ST (not STe) yet? I'm assuming so because of that
picture.
Any chance we could get some pictures of the ST version before installation
from various angles with approximate measurements? With the PiSTorm +
Pi 3/4 together?
I realize that's a lot of work... Thanks.
