"SuperVidel" style graphics for the DFB1X2?
Re: "SuperVidel" style graphics for the DFB1X2?
alexh wrote:Looking good. Are you thinking Display Port type digital display output or old skool R2R DAC for SVGA output?
It's digital, through a standard HDMI-type socket. The FPGA generates the TMDS signals and they go through a MAX3814 driver chip to the socket, the same way @Icky did it, rather than driving the socket straight from the FPGA pins.
It will send plain DVI video, which any HDMI monitor or TV accepts, the same as most FPGA projects do. (I'm not sure where HDMI licensing stands these days. I half recall V1.1 being licence free, or that later versions let you build 100 prototype units without one, but it's been some years since I last looked.)
There's no analogue output planned, so no R2R DAC. Audio is left out for now, but I'm putting a small header on spare FPGA pins so something can be added later.
The "plug in" board I was working on looked like this. It was basically routed all on the top layer on purpose.
But like I said before, its not going to fit in the Falcon case. Plus it just seems a bit daft to have a PLD and FPGA stacked against each other. Hence moving to a FPGA on the DFB1X2.. Bringing up the booster *should* be the simple part. Then the Videl stuff gets added later.
Routing the FPGA will take some time.. Its a pretty big board rebuild.
The PLD area was shifted to the top layer, and the videl routing gets shifted to the bottom. So you basically have DFB1X "on top" and "videl" on the bottom copper wise. Mix in other stuff and it turns into a hot mess very fast as I am finding out :lol: :roll:
