Atari-forum access issues. Is anybody else affected?
Cyprian
Re: Atari-forum access issues. Is anybody else affected?
Post by Cyprian »
I see only message "Forbidden You don't have permission to access this resource."
http://260ste.atari.org
@peters @Cyprian
My best suggestion is to contact @1024MAK as he's suggested if you are unable to get onto Atari-Forum through any other method such as VPN.
Cyprian
Post by Cyprian »
@rubber_jonnie thanks, with VPN AF works ok
Cyprian wrote: Fri Jun 12, 2026 11:06 am @rubber_jonnie thanks, with VPN AF works ok
No worries.
leech
Post by leech »
Interesting, it worked this morning, but is giving me the 403 forbidden again now. Amusingly, it seems the opposite is true of what you'd think it should do. One would think a VPN or ever changing IP from a mobile phone would block you... but I'm being blocked from my Fiber, which hasn't changed IPs in quite some time... if ever.
Post by JezC »
Well, until now I've not had any problems getting in to the site (using WiFi at home on my mobile or laptop) but as of this afternoon I'm getting connection refused...
It was working last night, I couldn't check this morning due to collecting my daughter from uni.
I'll try from a wired (fibre) connection later but that is the same router as the WiFi...
JezC wrote: Sat Jun 13, 2026 5:31 pm Well, until now I've not had any problems getting in to the site (using WiFi at home on my mobile or laptop) but as of this afternoon I'm getting connection refused...
Well I have just lost connection again and need to use a VPN to connect.
EDIT - As of this morning, 14th June all my access is back to normal.
Post by JezC »
I'm back able to connect on my phone over WiFi again...no changes on my side...
peters
Post by peters »
I managed to get access again from my phone but only by installing Opera-mini.
Ironically, my tablet and desktop pc work and they use chrome and brave and not even the latest versions.
