FPU Compatible Software
General Discussion, STOS.
thorsten.otto
Re: FPU Compatible Software
Post by thorsten.otto »
Yes, that's correct, the startup code calls _fpuinit in the library to check for presence of a memory-mapped FPU. If you have removed that call from your own startup code, then its your fault ;) (there might however be reasons for it, some emulators may not like the bus-error that will result most of the time).
And yes, i would also expect that memory-mapped FPU to be faster than pure software calculation. Otherwise it would not make much sense to develop such a device, or to support it in libraries. But it will still be much slower than a "real" FPU.
As to applications: Texel might be good candidate for it.
pixelpusher
Post by pixelpusher »
thorsten.otto wrote: Sat Jun 05, 2021 5:24 pm Yes, that's correct, the startup code calls _fpuinit in the library to check for presence of a memory-mapped FPU. If you have removed that call from your own startup code, then its your fault ;) (there might however be reasons for it, some emulators may not like the bus-error that will result most of the time).
I've somewhere a jpeg source lying around that I used at the end of the 90s on the ATARI and Mac which should be a good test with its DCT code (if you select the accurate output options).
pixelpusher
czietz wrote: Sat Jun 05, 2021 1:30 pm
pixelpusher wrote: Sat Jun 05, 2021 1:15 pm Some time ago I stumbled over the archive for fpu_emu (.zip) by H. Robbers & V. Hemsen. While being limited to support the memory mapped 68881 via LineF, it allows using the same FPU code that you would have used on system with 68020 (or newer) with FPUs.
We just discussed a similar program (once published in c't magazine) over at AF: https://www.atari-forum.com/viewtopic.php?f=14&t=40516
After finding out that the fpu_emu from Robers & Hemsen doesn't pass exxos' FPUTEST program, I digged further and found this discussion (it's in german ...): https://groups.google.com/g/maus.sys.at ... 3bLO0-EegJ
discussing two other alternatives (all of them based on the original c't magazine method). Of those two only one was ever published (LFED - with sources) and it passes exxos' FPUTEST completely. It still stumbles in GB 6, as GB 6 doesn't support the _FPU cookie being set to "LineF emulation present + SFP 004 present; in fact even patching that to LineF emulation present + 68881 wasn't sufficient; GB only accepts it if the low-word is zero). With that GB starts but triggers a crash later (so most likely something in the emulation isn't on spot or GB6 tests one of the 3 not supported instructions).
Anyway, LFED otherwise looks quite promising (see above google link). Speed for simple fadd/fsub instructions is about 1.5x slower than using SFP-004 (both still being faster than software float libs), but surprisingly trigonometric functions seem to execute faster with LFED than the SFP-004 support used by the C compiler (not true for assembler coding though).
I will have a look at GB6 FPU detection when I get home later. Also IIRC the FPU tests were done to be compatible between across all FPU setups. Also IIRC the 060 only had a basic list of internal instructions, so instructions were used which would be most compatible across all "types" of FPU.
pixelpusher
exxos wrote: Sun Jun 06, 2021 6:04 pm I will have a look at GB6 FPU detection when I get home later. Also IIRC the FPU tests were done to be compatible between across all FPU setups. Also IIRC the 060 only had a basic list of internal instructions, so instructions were used which would be most compatible across all "types" of FPU.
Thx! Let me know if I should upload the archive with LFED here (zip including sources + binary is only 68 kb) for testing...
pixelpusher wrote: Sun Jun 06, 2021 8:31 pm Thx! Let me know if I should upload the archive with LFED here (zip including sources + binary is only 68 kb) for testing...
This is what GB6 does..
'I/O mapped FPU = 68000 + FPU
'line F built in FPU into CPU ot 688881/2
DEF fpu$
STATIC fpu&
IF GETCOOKIE("_FPU",fpu&) THEN
   IF     fpu&=&h10000 THEN
      fpu$="I/O mapped FPU"
   ELSEIF fpu&=&h20000 THEN ' 68881/2 external
      fpu$="LineF FPU inst."
   ELSEIF fpu&=&h30000 THEN ' 68881/2 external
   ELSEIF fpu&=&h40000 THEN ' 68881/2 external
   ELSEIF fpu&=&h50000 THEN ' 68881/2 external
   ELSEIF fpu&=&h60000 THEN ' 68881/2 external
   ELSEIF fpu&=&h70000 THEN ' 68881/2 external
   ELSEIF fpu&=&h80000 THEN ' internal FPU 68040
      fpu$="Internal FPU"
   ELSEIF fpu&=&h90000 THEN ' internal FPU 68040
      fpu$="Internal FPU"
   ELSEIF fpu&=&h100000 THEN ' internal FPU 68060
      fpu$="Internal FPU"
   ELSEIF fpu&=0 THEN
      fpu$="FPU Not present"
   ELSE
      fpu$="Cookie =$"+HEX$(fpu&)
   END IF
ELSE
   fpu$="FPU not present"
END IF
END DEF
I don't really remember where that information came from tho..
pixelpusher
exxos wrote: Sun Jun 06, 2021 9:18 pm
DEF fpu$
STATIC fpu&
      fpu$="Internal FPU"
      fpu$="Internal FPU"
      fpu$="Internal FPU"
   ELSEIF fpu&=0 THEN
   ELSE
   END IF
ELSE
END IF
END DEF
This link contains the documentation for the _FPU cookie: http://toshyp.atari.org/en/003007.html#Cookie_2C_20_FPU
For the lower word (that your code always checks to be zero) it says:
The lower WORD is reserved for information about software support via the Line-F trap, and is at present not yet in use. According to Atari, a non-zero value indicates that Line-F support is present.
Can you spill some info what fpu code is called in your test?
pixelpusher wrote: Sun Jun 06, 2021 9:50 pm For the lower word (that your code always checks to be zero) it says:
I haven't been following this thread too closely and not sure what the software emulation is exactly doing.. I can add a bit0 check for =1 (is that regardless of all other bits ?) if you're saying it will run LINEF type instructions, but that could crash GB6 if it's not emulating exactly like a real FPU via LINEF. Of course IO mapped isn't supported at all.
pixelpusher wrote: Sun Jun 06, 2021 9:50 pm Can you spill some info what fpu code is called in your test?
*	Float FMUL,FDIV,FADD,FNEG,FSQRT,FCMP,FABS,FREM combined speed test
fprim_test:
	move.l		bas_params(pc),d2
	subq.l		#1,d2
	bmi.s		.err
	fmovem		fp0-fp7,-(sp)
.fprim_outer_loop:
	fmove.s		#1.001,fp0
	fmove.x		fp0,fp1
	fmove.x		fp0,fp2
	fmove.x		fp0,fp3
	fmove.x		fp0,fp4
	fmove.x		fp0,fp5
	move.w		#(1024/8)-1,d1 ; 1024 loops
.fprim_loop:
	fmul.x		fp2,fp3
	fdiv.x		fp4,fp5
	fadd.x		fp0,fp1
	fneg.x		fp5
	fsqrt.x		fp3
	fcmp.x		fp4,fp5
	fabs.x		fp1
	frem.x		fp3,fp4
	dbra		d1,.fprim_loop
	dbra 		d2,.fprim_outer_loop
	fmovem		(sp)+,fp0-fp7
.err:	rts
pixelpusher
exxos wrote: Sun Jun 06, 2021 10:03 pm if your saying it will run LINEF type instructions, but that could crash GB6 if it's not emulating exactly like a real FPU via LINEF. Of course IO mapped isn't supported at all.
The LineF emulation should make the machine behave as if the FPU was integrated on machines with 68020 or newer cpus and above code should just work. So if nothing quirky is done in GB (the posted code looks fine), then it's something to investigate and fix in the LineF emulation.
Regarding the checks: Yes, the lower word of the FPU cookie being 0x0001 is being set by this emulator, indicating that LineF based FPU opcodes can be used and the upper word still shows that the hardware for this is based on the SFP-004 (so this wouldn't show if a 68882 is used in a SFP-004 compatible hw, but that's not a priority problem atm). Note that ATARI said "any non-zero value indicates Line-F support", so 0xffff would have been fine too.
pixelpusher wrote: Mon Jun 07, 2021 11:28 am The LineF emulation should make the machine behave as if the FPU was integrated on machines with 68020 or newer cpus and above code should just work. So if nothing quirky is done in GB (the posted code looks fine), then it's something to investigate and fix in the LineF emulation.
OK will try and do a patch to GB6 later today. Hisoft doesn't have a Bit test function, so will have to code one :roll:
Return to “SOFTWARE”
