Yes, that's correct, the startup code calls _fpuinit in the library to check for presence of a memory-mapped FPU. If you have removed that call from your own startup code, then its your fault ;) (there might however be reasons for it, some emulators may not like the bus-error that will result most of the time).
And yes, i would also expect that memory-mapped FPU to be faster than pure software calculation. Otherwise it would not make much sense to develop such a device, or to support it in libraries. But it will still be much slower than a "real" FPU.
As to applications: Texel might be good candidate for it.
FPU Compatible Software
pixelpusher
Re: FPU Compatible Software
I've somewhere a jpeg source lying around that I used at the end of the 90s on the ATARI and Mac which should be a good test with its DCT code (if you select the accurate output options).thorsten.otto wrote: 05 Jun 2021 17:24 Yes, that's correct, the startup code calls _fpuinit in the library to check for presence of a memory-mapped FPU. If you have removed that call from your own startup code, then its your fault ;) (there might however be reasons for it, some emulators may not like the bus-error that will result most of the time).
pixelpusher
After finding out that the fpu_emu from Robers & Hemsen doesn't pass exxos' FPUTEST program, I digged further and found this discussion (it's in german ...): https://groups.google.com/g/maus.sys.at ... 3bLO0-EegJczietz wrote: 05 Jun 2021 13:30We just discussed a similar program (once published in c't magazine) over at AF: https://www.atari-forum.com/viewtopic.php?f=14&t=40516pixelpusher wrote: 05 Jun 2021 13:15 Some time ago I stumbled over the archive for fpu_emu (.zip) by H. Robbers & V. Hemsen. While being limited to support the memory mapped 68881 via LineF, it allows using the same FPU code that you would have used on system with 68020 (or newer) with FPUs.
discussing two other alternatives (all of them based on the original c't magazine method). Of those two only one was ever published (LFED - with sources) and it passes exxos' FPUTEST completely. It still stumbles in GB 6, as GB 6 doesn't support the _FPU cookie being set to "LineF emulation present + SFP 004 present; in fact even patching that to LineF emulation present + 68881 wasn't sufficient; GB only accepts it if the low-word is zero). With that GB starts but triggers a crash later (so most likely something in the emulation isn't on spot or GB6 tests one of the 3 not supported instructions).
Anyway, LFED otherwise looks quite promising (see above google link). Speed for simple fadd/fsub instructions is about 1.5x slower than using SFP-004 (both still being faster than software float libs), but surprisingly trigonometric functions seem to execute faster with LFED than the SFP-004 support used by the C compiler (not true for assembler coding though).
I will have a look at GB6 FPU detection when I get home later. Also IIRC the FPU tests were done to be compatible between across all FPU setups. Also IIRC the 060 only had a basic list of internal instructions, so instructions were used which would be most compatible across all "types" of FPU.
pixelpusher
Thx! Let me know if I should upload the archive with LFED here (zip including sources + binary is only 68 kb) for testing...exxos wrote: 06 Jun 2021 18:04 I will have a look at GB6 FPU detection when I get home later. Also IIRC the FPU tests were done to be compatible between across all FPU setups. Also IIRC the 060 only had a basic list of internal instructions, so instructions were used which would be most compatible across all "types" of FPU.
This is what GB6 does..pixelpusher wrote: 06 Jun 2021 20:31 Thx! Let me know if I should upload the archive with LFED here (zip including sources + binary is only 68 kb) for testing...
'I/O mapped FPU = 68000 + FPU
'line F built in FPU into CPU ot 688881/2
DEF fpu$
STATIC fpu&
IF GETCOOKIE("_FPU",fpu&) THEN
IF fpu&=&h10000 THEN
fpu$="I/O mapped FPU"
ELSEIF fpu&=&h20000 THEN ' 68881/2 external
fpu$="LineF FPU inst."
ELSEIF fpu&=&h30000 THEN ' 68881/2 external
ELSEIF fpu&=&h40000 THEN ' 68881/2 external
ELSEIF fpu&=&h50000 THEN ' 68881/2 external
ELSEIF fpu&=&h60000 THEN ' 68881/2 external
ELSEIF fpu&=&h70000 THEN ' 68881/2 external
ELSEIF fpu&=&h80000 THEN ' internal FPU 68040
fpu$="Internal FPU"
ELSEIF fpu&=&h90000 THEN ' internal FPU 68040
fpu$="Internal FPU"
ELSEIF fpu&=&h100000 THEN ' internal FPU 68060
fpu$="Internal FPU"
ELSEIF fpu&=0 THEN
fpu$="FPU Not present"
ELSE
fpu$="Cookie =$"+HEX$(fpu&)
END IF
ELSE
fpu$="FPU not present"
END IF
END DEF-
pixelpusher
This link contains the documentation for the _FPU cookie: http://toshyp.atari.org/en/003007.html#Cookie_2C_20_FPUexxos wrote: 06 Jun 2021 21:18This is what GB6 does..pixelpusher wrote: 06 Jun 2021 20:31 Thx! Let me know if I should upload the archive with LFED here (zip including sources + binary is only 68 kb) for testing...
I don't really remember where that information came from tho..Code: Select all
'I/O mapped FPU = 68000 + FPU 'line F built in FPU into CPU ot 688881/2 DEF fpu$ STATIC fpu& IF GETCOOKIE("_FPU",fpu&) THEN IF fpu&=&h10000 THEN fpu$="I/O mapped FPU" ELSEIF fpu&=&h20000 THEN ' 68881/2 external fpu$="LineF FPU inst." ELSEIF fpu&=&h30000 THEN ' 68881/2 external fpu$="LineF FPU inst." ELSEIF fpu&=&h40000 THEN ' 68881/2 external fpu$="LineF FPU inst." ELSEIF fpu&=&h50000 THEN ' 68881/2 external fpu$="LineF FPU inst." ELSEIF fpu&=&h60000 THEN ' 68881/2 external fpu$="LineF FPU inst." ELSEIF fpu&=&h70000 THEN ' 68881/2 external fpu$="LineF FPU inst." ELSEIF fpu&=&h80000 THEN ' internal FPU 68040 fpu$="Internal FPU" ELSEIF fpu&=&h90000 THEN ' internal FPU 68040 fpu$="Internal FPU" ELSEIF fpu&=&h100000 THEN ' internal FPU 68060 fpu$="Internal FPU" ELSEIF fpu&=0 THEN fpu$="FPU Not present" ELSE fpu$="Cookie =$"+HEX$(fpu&) END IF ELSE fpu$="FPU not present" END IF END DEF
For the lower word (that your code always checks to be zero) it says:
The lower WORD is reserved for information about software support via the Line-F trap, and is at present not yet in use. According to Atari, a non-zero value indicates that Line-F support is present.
Can you spill some info what fpu code is called in your test?
I haven't been following this thread too closely and not sure what the software emulation is exactly doing.. I can add a bit0 check for =1 (is that regardless of all other bits ?) if you're saying it will run LINEF type instructions, but that could crash GB6 if it's not emulating exactly like a real FPU via LINEF. Of course IO mapped isn't supported at all.pixelpusher wrote: 06 Jun 2021 21:50 For the lower word (that your code always checks to be zero) it says:
* Float FMUL,FDIV,FADD,FNEG,FSQRT,FCMP,FABS,FREM combined speed test
fprim_test:
move.l bas_params(pc),d2
subq.l #1,d2
bmi.s .err
fmovem fp0-fp7,-(sp)
.fprim_outer_loop:
fmove.s #1.001,fp0
fmove.x fp0,fp1
fmove.x fp0,fp2
fmove.x fp0,fp3
fmove.x fp0,fp4
fmove.x fp0,fp5
move.w #(1024/8)-1,d1 ; 1024 loops
.fprim_loop:
fmul.x fp2,fp3
fdiv.x fp4,fp5
fadd.x fp0,fp1
fneg.x fp5
fsqrt.x fp3
fcmp.x fp4,fp5
fabs.x fp1
frem.x fp3,fp4
dbra d1,.fprim_loop
dbra d2,.fprim_outer_loop
fmovem (sp)+,fp0-fp7
.err: rts-
pixelpusher
The LineF emulation should make the machine behave as if the FPU was integrated on machines with 68020 or newer cpus and above code should just work. So if nothing quirky is done in GB (the posted code looks fine), then it's something to investigate and fix in the LineF emulation.exxos wrote: 06 Jun 2021 22:03 if your saying it will run LINEF type instructions, but that could crash GB6 if it's not emulating exactly like a real FPU via LINEF. Of course IO mapped isn't supported at all.
Regarding the checks: Yes, the lower word of the FPU cookie being 0x0001 is being set by this emulator, indicating that LineF based FPU opcodes can be used and the upper word still shows that the hardware for this is based on the SFP-004 (so this wouldn't show if a 68882 is used in a SFP-004 compatible hw, but that's not a priority problem atm). Note that ATARI said "any non-zero value indicates Line-F support", so 0xffff would have been fine too.
OK will try and do a patch to GB6 later today. Hisoft doesn't have a Bit test function, so will have to code one :roll:pixelpusher wrote: 07 Jun 2021 11:28 The LineF emulation should make the machine behave as if the FPU was integrated on machines with 68020 or newer cpus and above code should just work. So if nothing quirky is done in GB (the posted code looks fine), then it's something to investigate and fix in the LineF emulation.
