Sporniket's log on hardware stuff
ijor
Re: Sporniket's log on hardware stuff
Post by ijor »
sporniket wrote: Fri Jan 13, 2023 8:18 am This week I migrated my workstation to the latest LTS Ubuntu, as a consequence this project is now using Kicad 6.
Great work. Thanks for sharing your work.
But note that pin 52 is TEST, not GND. Even when in some Atari schematics it is named as GND, and it is of course tied to GND in anycase, what matters here is the actual pin function, not the connection.
http://pasti.fxatari.com
sporniket
Post by sporniket »
Thanks for the fix @ijor, it seems that the author of "Atari ST internal" was not aware of the function of that pins.
This is the reference I used to make the symbol : https://raw.githubusercontent.com/sporn ... ernals.pdf
edit: same with the Profibuch ST-STE-TT
edit 2 : same in the IC Pinout thread : viewtopic.php?f=31&t=149 ; it seems @troed posted a fix to the SMD version of the chip. Is there a public reference somewhere so that I can cite in my source datasheet ?
ijor
Post by ijor »
sporniket wrote: Fri Jan 13, 2023 8:06 pm Thanks for the fix @ijor, it seems that the author of "Atari ST internal" was not aware of the function of that pins.
ST Internals and all other early books had no other reference but the older Atari schematics. As I said, the pin is named as GND in those older schematics ...
Is there a public reference somewhere so that I can cite ...
Check the newer Atari schematics, like this one:
https://archive.org/details/Atari_1040S ... 1986_Atari
Anyway, trust me, I decapped the chip and I've seen the chip internal logic. The pin is not GND.
ijor
Post by ijor »
sporniket wrote: Fri Jan 13, 2023 8:06 pm my source datasheet ?
Btw, the direction of many pins are wrong there. I'll need to check to make a detailed list, but i.e, the address bus is input only.
sporniket
Post by sporniket »
ijor wrote: Fri Jan 13, 2023 9:49 pm
Thanks for the reference. And I trust you.
ijor wrote: Sat Jan 14, 2023 1:08 am
thanks in advance, I am looking forward to get your list :)
sporniket
Post by sporniket »
Some routing done.
Rendering from above:
Rendering from below:
For the record @ijor , I created a github issue to track your feedbacks to fix the symbol : https://github.com/sporniket/kicad-symb ... /issues/54
ijor
Post by ijor »
sporniket wrote: Fri Jan 20, 2023 9:31 pm For the record @ijor , I created a github issue to track your feedbacks to fix the symbol : https://github.com/sporniket/kicad-symb ... /issues/54
Sorry, I forgot. Let's see ...
An       I
RESET    I
RDY      B
BERR     0
HSYNC    B
VSYNC    B
These are only the ones that were wrong. Hope I didn't miss anything
sporniket
Post by sporniket »
ijor wrote: Sat Jan 21, 2023 1:44 am
BERR     0
Just to be sure, BERR is Output ? (mistyping between zero and uppercase 'o' ?)
Many thanks @ijor
ijor
Post by ijor »
sporniket wrote: Sat Jan 21, 2023 5:55 am Just to be sure, BERR is Output ? (mistyping between zero and uppercase 'o' ?)
That's correct.
sporniket
Post by sporniket »
Here is the fixed subsheet with the GLUE.
The github is up to date.
