agranlund
Post by agranlund »
dml wrote: Fri Aug 08, 2025 3:22 pm Maybe some other Raven builders are interested in running the test themselves and see what happens?
I'm getting exactly the same results as you observed in your machine with 40 and 48mhz oscillators.
Would be interesting to know the magnitude of the error compared to expected result, or if they're complete garbage.
I only have three programs I know for sure is using the FPU and they appear to work fine but it sounds like they technically aren't then. Perhaps the error is not significant enough to matter for non-science stuff?
Quake, makes heavy use of FPU all over the place
Doom, for muls and divs if FPU is available
mxPlay, minimal use for the GUI sliders.
dml
Post by dml »
agranlund wrote: Sat Aug 09, 2025 7:34 pm I only have three programs I know for sure is using the FPU and they appear to work fine but it sounds like they technically aren't then. Perhaps the error is not significant enough to matter for non-science stuff?
Yep I'm afraid I don't know the magnitude of the error or if it's confined to e.g. the multiplier only. But there is some kind of randomness creeping into results at high OC levels on my CPU.
It could be the LSBs or the rounding bits or something like that which don't show up much in real world stuff. I'll need to look at it a bit more closely. All I can say is that the computed results, when treated as binary IEEE encodings and hash-summed over a series of operations, isn't the same between runs (and with the initial FPCR state and conditions etc. always known at the start of the test).
I also don't see any actual instability, even if I haven't been running FPU intensive stuff yet - but I do have plans to use FPU soon :)
I've always been concerned with how people like to overclock the 060 to 90+ MHz, for such a rare and expensive CPU I've never thought it a good idea. Why would you get a classic car engine and thrash it to the highest RPMs is my analogy, I suppose the FPU test really is the ultimate when showing the true safe overclocks.
agranlund
Post by agranlund »
LarryL wrote: Fri Aug 08, 2025 7:46 am @agranlund - how is the timeline for the A2 version of the board?
any plans to release this anyway soon?
Hi! Oh that's really hard to say since I haven't given it that much thought -- and I haven't been in that much of a rush, even though I do regularly feel that I could do with having two board myself.
I had a bit of a sprint in Kicad a while ago and then decided to let it rest for a bit. Partly to get fresh eyes before finalising and checking it over before ordering, and partly to decide if another larger change should go to this board or back to the ideas box for the future.
But maybe mostly because I wanted to do some programming instead.
The board is near enough there but knowing myself I can't commit to when I'll go back to working on it, so if it was me I _think_ I'd go for the current version? I'm easily distracted and jump a bit all over the place :)
--Anders
LarryL
Post by LarryL »
agranlund wrote: Sat Aug 09, 2025 8:46 pm
Thanks Anders,
I can totally understand this - I do experience this myself, too :-) many parallel projects and jumping from one to the other…
Lets see, what the others think, but I doubt they are in a rush
Take your time - when it is ready, it is ready
…and it surely will be great :-)
Cheers
Michael
TheNameOfTheGame
Post by TheNameOfTheGame »
Yes, no hurry, but I am waiting for A2 version to build one. Enjoying reading about everyone's current builds though.
Mikerochip
Post by Mikerochip »
LarryL wrote: Sat Aug 09, 2025 9:28 pm Take your time - when it is ready, it is ready
You've a board to ready too @LarryL :D
TheNameOfTheGame wrote: Sun Aug 10, 2025 3:33 am Yes, no hurry, but I am waiting for A2 version to build one. Enjoying reading about everyone's current builds though.
ONE OF US! ONE OF US!
@agranlund Can I just use a ROM programmer, to program the ICs individually, instead of using the ROM programmer PCB.
(Is it interleaved or location specific?)
I'm just curious.
I've (almost) built two rom simm programmers :D I'm just wondering if I can use the XGecu T48 to program them, before the simms sockets arrive!
agranlund
Post by agranlund »
@Mikerochip yep, should be possible. Each 32bit dword of the rom is interleaved across the four chips.
(I think the XGecu software has options to de-interleave when loading a binary, otherwise you could probably find or make a splitter tool)
agranlund
Post by agranlund »
And now my WD90C31 card can suddenly do this :)
The card has hardware acceleration but the driver isn't capable of using any such stuff yet.
But it sure would be nice to make use of the blitter to get more sensible blit and scrolling performance.
I'm testing a CirrusLogic and OAK card in parallel and they're also going into SuperVGA but have more kinks to work out.
It's mostly for me to have more than one low-level "client" for the base framework as I find that helps in getting the design good-ish, and to have more than one example should someone find the urge to implement a driver for some other card.
I do plan on trying to support auto-bankswitch for the older cards which only have banked SVGA modes. A bit similar to virtual memory in that the driver would provide a (virtual) linear framebuffer as required by VDI, and then switch in correct bank behind the scenes on access violations.
Not sure how useful that is in real life since cards of that age are quite slow to begin with, but fun for me.
@agranlund that's good news. I was going to try and disassemble the vdi drivers at some point and have a go at doing drivers.
I've got a cl-gd5429 and an S3 board to play with at some point.
I shall be looking on with interest on this one.
