Yep I'm afraid I don't know the magnitude of the error or if it's confined to e.g. the multiplier only. But there is some kind of randomness creeping into results at high OC levels on my CPU.agranlund wrote: Sat Aug 09, 2025 7:34 pm I only have three programs I know for sure is using the FPU and they appear to work fine but it sounds like they technically aren't then. Perhaps the error is not significant enough to matter for non-science stuff?
It could be the LSBs or the rounding bits or something like that which don't show up much in real world stuff. I'll need to look at it a bit more closely. All I can say is that the computed results, when treated as binary IEEE encodings and hash-summed over a series of operations, isn't the same between runs (and with the initial FPCR state and conditions etc. always known at the start of the test).
I also don't see any actual instability, even if I haven't been running FPU intensive stuff yet - but I do have plans to use FPU soon
