ACORN A5000 inbound
Re: ACORN A5000 inbound
Looks like almost as much track damage around the IDE/Floppy connectors as mine had.
chronicthehedgehog
Post by chronicthehedgehog »
Wow. How do you manage to get the wire so straight?
HigashiJun
Post by HigashiJun »
rubber_jonnie wrote: Tue Dec 05, 2023 12:11 am Looks like almost as much track damage around the IDE/Floppy connectors as mine had.
I have two traces repaired just in case... There was continuity but the traces looked very weak.
HigashiJun
chronicthehedgehog wrote: Tue Dec 05, 2023 12:12 am Wow. How do you manage to get the wire so straight?
I use kynar wire (0.5mm), and once a side is soldered you just have to route it and then solder the other side.
It remains quite straight, but you can adjust it once completely soldered.
HigashiJun
Ok, so here's the result of the motherboard repair:
A close-up of the connectors area, which were most affected with corrosion.
The whole motherboard
And its backside.
Next steps tomorrow...
:bravo: :coolpics:
HigashiJun
:cheers:
Nice repair, hope it ll works :)
HigashiJun
Thanks !
Me too...
HigashiJun
Seems OK after all the repairs...
The mouse has some issues though, as the buttons are OK but the cursor doesn't move on the screen...
Have to check all the details tomorrow.
