ACORN A5000 inbound
Re: ACORN A5000 inbound
Looks like almost as much track damage around the IDE/Floppy connectors as mine had.
chronicthehedgehog
Wow. How do you manage to get the wire so straight?
I have two traces repaired just in case... There was continuity but the traces looked very weak.rubber_jonnie wrote: 05 Dec 2023 00:11 Looks like almost as much track damage around the IDE/Floppy connectors as mine had.
I use kynar wire (0.5mm), and once a side is soldered you just have to route it and then solder the other side.
It remains quite straight, but you can adjust it once completely soldered.
Ok, so here's the result of the motherboard repair:
A close-up of the connectors area, which were most affected with corrosion.
The whole motherboard
And its backside.
Next steps tomorrow...
And its backside.
:bravo: :coolpics:
:cheers:
Thanks !
Me too...
Me too...
Seems OK after all the repairs...
The mouse has some issues though, as the buttons are OK but the cursor doesn't move on the screen...
Have to check all the details tomorrow.
Users browsing this forum: ClaudeBot, trendiction [bot] and 30 guests
