Sporniket's log on hardware stuff
Re: Sporniket's log on hardware stuff
So how close is the routing to the original STE ? I'm thinking maybe it could be seen exactly how Atari did the grounding around the DMA to CPU areas...
@exxos , for all traces except grounding, I try to keep the same relative position between traces and components. Meaning if trace A goes between B and C on the real mother board, it will be the same on the motherboard, 90% of the time.
A picture to illustrate, here is a close up of the component side around the GSTMCU, and the result of my work :
So you will get a rough idea of through which area a signal goes between CPU and DMA, but I don't know if it will be of help to you. I am quite sure that if someone make a build from my PCB, it will be mostly luck that it works. At least there should be no short.
For the grounding I am cheating with 2 inner ground planes. On the real motherboard, I can see that any unoccupied space of the board constitute grounding.
No big deal anyway
. Glad you're doing away with those right angles at least
At least one thing that I'm doing right
The routes are all done, now I am working on the copper fillings, meaning also the separation of analog parts. There are 2 analog areas, the sound and the video. Like the traces, I loosely follows what I see on my motherboard.
I left some disclaimers on the silkscreen...
Anyway, the front side is done.
I hope to make a new release candidate by next week. Then I plan to add comments about some fixes that would be helpfull and their references ( #mandatoryFixes
Anyway, doing a complete PCB proved to be a valuable tool to proofread my schematics.
edit : the github repository is up to date, as usual. (see my signature for the repo).
Well done! Looks really nice.
Yes, it is very satisfying in itself
The back side now.
Now it's time to tidying things before release...
Today I am working on the Lynx 2 that is still running, but with a screen too bright and around 7V at C41, and non working off-on, the only way to put-remove batteries.
Before that, I assembled a battery holders for easier testing when the console is opened :
Now, back on this "still running Lynx", I had noticed a suspicious bodge wire :
It turns out that it is a mode using the headphone pins to bypass the voltage regulator circuitry, so I removed it -and reflowed the solder joints-.
Side note : I can now compare non-leaded vs leaded solder handling, and now I understand all the frustration I read here and there regarding non-leaded solder. With leaded solder, I became magically good at soldering, and at using the solder wick. I guess that my faithful 25W-entry-level soldering iron and its pointy tips, while totally suitable for leaded solder, are barely suitable for non-leaded soldering (especially on pads connected to ground or large copper areas...)
Then I prepared to for testing...
... And nothing happens
. A close look at the mother board, I can see that it is brownish around Q8, so next time I can make an order to mouser, I will try to replace that transistor.
The last -hopefully- release candidate before the real one.
https://github.com/sporniket/kicad-conv ... /1.0.0.rc4
This release includes :
- A standalone Kicad project (all custom libraries included and ready to use)
- A PDF of the schematics
- A PDF of the silkscreen
- A small gallery
- DMA pull-up on databus (done on the floppy disc controller U301)
- WD1772 pull-ups (done on U305)
- LMC audio mix fix (done near U508)
- RGB Video ghosting fix (done at C411)
