New project: Repro Camputers Lynx
Re: New project: Repro Camputers Lynx
I intend to do the 4164 upgrade and power supply replacement at some point in the future.
Phew!
Well, ran out of 14 pin and 16 pin dual wipe sockets... RS order placed.
Had exactly the same problem with my Atom...stephen_usher wrote: Thu Mar 26, 2026 12:40 pm Well, ran out of 14 pin and 16 pin dual wipe sockets... RS order placed.
I really need to see what I'm missing socket wise and just order some.
Resistors, diodes (except for a couple I don't need at the moment) and transistors (except for one I don't need) are on the board.
Ran a power test as I had to use some equivalent transistors, some had different pinouts, and all is fine. Pulling 32mA currently.
Looks like my RS order is the last item in the DHL delivery van today, stop 93. So a long wait.
Yeah I know the feeling about equivalents...stephen_usher wrote: Thu Mar 26, 2026 10:19 pm Ran a power test as I had to use some equivalent transistors, some had different pinouts, and all is fine. Pulling 32mA currently.
I replaced some n one of my Speccys and though direct equivalents the pinouts were reversed and it didn't work so well initially.
I've been studying the schematic today in KiCAD.
Well, I wonder why they used two odd values of decoupling cap, 47nF and 22nF. They're just decoupling the TTL chips and RAM power rails. Half the ones on the RAM aren't needed as they're there for if you use 4116 chips as they're on the -5V rail.
I think I'll just throw my standard decoupling caps on the board and be done with it.
Likely targeting different frequencies for decoupling.(but depends on package size) So for example..stephen_usher wrote: Fri Mar 27, 2026 12:43 pm Well, I wonder why they used two odd values of decoupling cap, 47nF and 22nF. They're just decoupling the TTL chips and RAM power rails.
0603:
100nF ~100 kHz – 15 MHz
47nF ~300 kHz – 23 MHz
22nF ~500 kHz – 34 MHz
Leaded:
100nF ~5 MHz
47nF ~7.3 MHz
22nF ~10.7 MHz
I used 1uF, 100nF, 4.7nF on my updated ST536 rails
The Lynx is 6MHz, so I guess that the 47nF leaded is fine. Given how far away from the chips most of the caps are I'm not sure how much use they are anyway.
