Building a PAK030
frank.lukas
Re: Building a PAK030
Post by frank.lukas »
No, I don't have any boards. I got the two adapters from the German Atari forum. Ask Pakman. I'd have to create a layout in Eagle ...
Post it -> https://forum.atari-home.de/index.php/t ... #msg272677
The circuit boards are difficult to solder because you have to cut off the pins under the chips and solder them from below, which is difficult.
bbisi wrote: Wed Jun 18, 2025 5:49 pm hallo Frank
Hast du noch solch eine Platine
bestücken würde ich mit meinen IDT71B74S20Y
Oder nur das Platinen Layout
Grüße
It's possible I may have some. Is that the specific part number of the chip you require?
frank.lukas
Grüße
https://github.com/zxshock/PAK68_tagram_soj-dil
bbisi
Post by bbisi »
Danke für die Hilfe
Habe gerade 3 Stück aus China bestellt
Sollen übermorgen kommen
Gruß
bbisi
Post by bbisi »
Danke für die Hilfe
Habe gerade 3 Tag Rams MK48S74N20 aus China bestellt
Gruß
@bbisi Please note this is a English only forum thanks :)
bbisi
Post by bbisi »
Thanks for the help.
I just ordered 3 RAMs MK48S74N20 from China.
Should arrive the day after tomorrow.
Excuse me for German translation
I am not good in english
greetings
