FOR FREE: Ethernec
kodak80
Re: FOR FREE: Ethernec
Post by kodak80 »
JezC wrote: Tue Jun 10, 2025 9:53 pm Once you have confirmed it's working, would you mind sharing the details of who you used to build the PCBs?
I've not ordered any PCBs directly yet, so don't want to muck up if I can help it...so having a 'safe' first order would be a huge help...
No rush, I'm busy fighting floppy issues on several of my remake boards at the moment....
:roll:
Okay, cartridge adapter board works. Had to use a right-angled 40 pin header on the PCB for it to fit through the Atari casing. Straight 40 pin header would not allow it to be inserted into the cartridge socket.
Here are the gerbers for both components. ISA network card should be inserted into the slot with the front at the end where R1 is located.
Atari ST EtherNEC 2022 cartridge adapter-top.png (133.85 KiB) Viewed 1263 times
Atari ST EtherNEC 2022 cartridge adapter.zip
(22.88 KiB) Downloaded 31 times
EtherNEC2022.zip
(57.02 KiB) Downloaded 31 times
Post by JezC »
Thanks @kodak80 - I'll see if I can work out how to order those at some point soon...
