Getting Tyrian up and running
luciodra
Re: Getting Tyrian up and running
Post by luciodra »
There is no special thing to do to use Tyrian: simply copy the given directory into the game folder.
But what about other games like Doom?
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
I've not got Doom yet. DOTT works but with ST audio, not got the Picogus working yet.
luciodra
Post by luciodra »
Try what I sent you.
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
luciodra wrote: Wed May 21, 2025 7:43 pm Try what I sent you.
Yes Doom works fine on the ET4000, not tried Mach32 yet. No sound yet but I bet that's using midi?
luciodra
Post by luciodra »
I use Oplmidi.prg in auto folder.
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
luciodra wrote: Wed May 21, 2025 8:00 pm I use Oplmidi.prg in auto folder.
Okay, will give that a try in the morning.
So it's sounding like my graphics cards are the issue then.
agranlund
Post by agranlund »
This is just a wild guess, maybe it’s related to adlib sound?
Perhaps my card detect/init code is dogy and stuff goes south if no such card is present. Or something is not playing well with the picogus (you mentioned you don’t have it up and running yet)
Does doom work at all if you start it with -adlib ?
(Should make it take that codepath instead of midi)
ScummST plays music through midi, but @luciodra ’s suggestion to try oplmidi.prg sound like a good idea to get one more thing testing it.
I do believe I've fixed my Tyrian problem :D
I had to refresh the Picogus with the latest software and then configure it
Using PGUSINIT /mode sb set it to soundblaster mode and now Tyrian loads.
Thanks for your help guys.
luciodra
Post by luciodra »
When you run pgusinit /mode sb
and then pgusinit /save, does it return error messages at the end? :?:
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
luciodra wrote: Thu May 22, 2025 4:37 pm When you run pgusinit /mode sb
Yes it says that I've not set the sound blaster variables and doesn't save.
