I ran Gembench overnight, with the STorm installed and everything running at 40mhz:
- STacy-Gembench-Loop144.JPG (139.84 KiB) Viewed 730 times
Best I'm capable of getting, I reckon. I still have the same problem I've had since day 1
with this board - I can't run full speed (50mhz) without problems. I can disable the FPU
on the Pak board (J3) and it will run at 50mhz and seem very solid. Just not with it
enabled. It will boot up, but sometimes gives a 2 bomb error that continues on to the
desktop. From there, FPU Test 6-7 bombs completely. Gembench will run until it accesses
the FPU, then also crashes.
At 40mhz, both Gembench and FPU Test complete without errors.
I tried different 68882's - I have 3 of them, all rated at 50mhz. Here they are:
- 68882 FPUs.JPG (197.06 KiB) Viewed 730 times
All 3 will pass Gembench at 40mhz. Only #2 will pass with no errors with FPU Test.
At 40mhz, with #2, it seems rock solid though. That was the setup when I ran GB
overnight without issue.
<shrugs> I guess I can live with a 40mhz 68030/40mhz 68882, TOS v3.06 STacy.
(it just irks me that I can't eeek out that last 10mhz!!!)
