[Fixed] STE Floppy Drive Clue
doc
Re: [Fixed] STE Floppy Drive Clue
Post by doc »
Just a question...
Before the fix and after too, I still have an error playing the Printer/Joystick Port Test using the diagnostic cartridge.
Could somebody explain why as the STE now works perfectly ?
ijor
Post by ijor »
doc wrote: Wed Feb 08, 2023 7:02 pm Before the fix and after too, I still have an error playing the Printer/Joystick Port Test using the diagnostic cartridge.
Some diag cart tests, like these ones, require a loopback.
http://pasti.fxatari.com
What @ijor said is correct.
This is the harness I have for use with the diagnostic cart:
It includes loopback connectors for:
  1. ACSI
  2. Centronics (Printer)
  3. Both DB9 joystick ports
  4. Serial port (9 and 25 pin loopback dongles separate from the main harness)
The one thing I don't have is test connectors for the DB15 enhanced joystick ports on the STE. I can't say if they ever existed, but these always fail when I run the diag cart for that reason.
Without the harness you have to accept some tests will fail, even if the machine works just fine in practice.
doc
Post by doc »
Interesting... ;)
