FALCON030 which only boots on ROM
ylf22300
Re: FALCON030 which only boots on ROM
Post by ylf22300 »
stephen_usher wrote: Sun Oct 09, 2022 8:19 am Before you fit the clock patch run the tests to see if you actually need it in the first place. My machine didn’t.
What kind of tests must be run ? a specific software ?
There's the ACE Tracker which seems to push the system to the limit and this tool which apparently Atari used to test machines after they'd patched machines.
Dlfrsilver
Post by Dlfrsilver »
Beware, on mine, it seemed at first to not be needed, and finally, i have discovered that there was file corruption happening without warning !
So in the end, i have installed Exxos clock patch, and then, no more corruption, the machine operates normally.
I think its also worth noting that you can't take the tests as gospel. They are very dependant on a full moon/ alignment of the planets, ritual chicken sacrifice and what side of your bed you got out of in the morning etc
