Help find capacitor
Re: Help find capacitor
exxos wrote: Fri Apr 09, 2021 11:33 am Just as a side note, High voltage capacitors near rectifier are usually suppression capacitors XY rated type stuff. They are designed to take a lot more hammering than regular caps are.
This one seems to be a good page about them..
https://www.allaboutcircuits.com/techni ... apacitors/
I've watched quite a bit on Big Clive about X/Y class caps and did wonder if it was for that purpose.
rubber_jonnie wrote: Fri Apr 09, 2021 11:41 am I've watched quite a bit on Big Clive about X/Y class caps and did wonder if it was for that purpose.
yep.. Normal capacitors would say have a 400V rating may take voltages up to double that for very short amounts of time. The XY caps can withstand peak voltages up to even several thousand volts. They are just designed to take the abuse which can come down the mains line and suppress it to stop it from killing the rectifier and other components as easily etc ordinarily a normal capacity would just simply explode.. It could have just simply being the reason for the failure in the original post.
exxos wrote: Fri Apr 09, 2021 11:46 am
Yes, quite possible that it had had enough abuse from the mains and died.
Hey guys, I replaced the capacitor and bridge rectifier but it still isn't working. I made sure the input is getting 240v AC but I'm getting nothing on the DC output. I checked the round slow blow fuses and they seem fine. Can anyone else recommend what might be worth checking / replacing? Or the next logical step.
Is the bridge rectifier getting AC and providing DC? If not then that's where I'd start and then work my way through part by part.
Yeah makes sense thx :)
Return to “ELECTRONICS”
