TFMSX Arrives
Re: TFMSX Arrives
Wow! nice work, I don't know much about the MSX except there are a few different generations/versions - where does your home-made one fit compared to the others spec wise?
Re: TFMSX Arrives
First issue with the TFMSX. I was trying to clock the Z80 with a 3.3v clock. It appears to need a VCC-0.6v minimum for high on the clock lines. Everything else is much less picky so i found a 74LVC1G17 chip and patched it on there.
Seems much happier now as i see RD wiggle furiously.
WhatsApp Image 2021-04-08 at 22.13.22.jpeg (322 KiB) Viewed 5085 times
Re: TFMSX Arrives
exxos approves the bodge wires :lol: :thumbup:
Cheshire Noir
Re: TFMSX Arrives
Post by Cheshire Noir »
terriblefire wrote: Thu Apr 08, 2021 2:13 pm Well right now its a pet project.
Indeed, and a worthy pet project too. I'm just enjoying watching it get built. Somewhere down the track, if/when you release them to the usual suspects (And I have no expectations that this will happen, and want no part in applying any pressure for this to be anything more than a fun pet project for you) I'll probably see if I can purchase one. Not this year, however, as I am buying peripherals for all the systems I already own. So... many... shiny... systems!
Chesh
Re: TFMSX Arrives
It’s alive!!!
Ok so this wasnt so straightforward. Adding the Schmitt buffer made the clock line ring like a church bell. and it didnt run at 3.58Mhz.
So now i need to make another one for @arkadiusz.makarenko so he can do the keyboard.
b_squared
Re: TFMSX Arrives
Post by b_squared »
Great work, I'm excited to see what will come of this! MSX user since 1990 here. Two questions:
  1. Which BIOS are you using here?
  2. How are you handling cycles to the VDP for the turbo modes? Did you hook up the /WAIT signal?
Re: TFMSX Arrives
I'm presently using the Bios from a HX-10.. keeping at simple as possible.
I've no turbo modes setup yet. but when i do i'll change CPU speed for different accesses so that VDP will always be at 3.58Mhz..
If anyone is interested the board uses 600mA @5V idling at a basic prompt.
arkadiusz.makarenko
Re: TFMSX Arrives
Post by arkadiusz.makarenko »
:O
That was quick.
~ Stanislaw Lem
Re: TFMSX Arrives
arkadiusz.makarenko wrote: Sat Apr 17, 2021 9:25 am :O
That was quick.
Yeah i need some help now! :D USB keyboard!!!!
Here is how the keyboard matrix map looks...
PC0-3 are connected to the ARM like...
PC0 = ARM PIN8
PC1 = ARM PIN9
PC2 = ARM PIN10
PC3 = ARM PIN11
and the return signal to the MSX
 PB0 = ARM PIN 14
 PB1 = ARM PIN 15
 PB2 = ARM PIN 16
 PB3 = ARM PIN 17
 PB4 = ARM PIN 20
 PB5 = ARM PIN 21
 PB6 = ARM PIN 22
 PB7 = ARM PIN 23
I'll build you a board if i have time otherwise i'll ship you the number 1 prototype.
arkadiusz.makarenko
Re: TFMSX Arrives
I can find time for this... :)
~ Stanislaw Lem
