Wow, that's awesome!!!terriblefire wrote: Fri Oct 16, 2020 8:19 amJust ordered 5 PCs. Will send you one when they arrive.GadgetUK164 wrote: Fri Oct 16, 2020 12:07 am It's open source by the looks of it. I was going to try and order it but unfamilar with how the gerber files are structured and named there. DirtyPCBs seems to like everything having a .gbr extension with a seperate extention for the drill files and the cuts file. At the bottom of that page is the link to the bom and gerbers (in one zip on aminet).
Design of the board looks good. I think i might be able to improve on the CPLD firmware.
EDIT: Only thing i would change about the board is to make it 4 layer.
Scandoubler /Flicker fixer
- GadgetUK164
Re: Scandoubler /Flicker fixer
- Admin sponsor
Then i will fix the firmware.GianDO wrote: Fri Oct 16, 2020 10:10 am It will also be well made, but if you see half the screen ...
so the fact that it doesn't show full screen is just a matter of firmware?terriblefire wrote: Fri Oct 16, 2020 10:59 amThen i will fix the firmware.GianDO wrote: Fri Oct 16, 2020 10:10 am It will also be well made, but if you see half the screen ...
A2000 - MC68000 - KS3.1 - WB 3.1 - 2MB ChipRAM - Impact A2000-HC+8 Series II - 8 MB FastRAM - SD2SCSI 16GB - Indivision ECS
- Admin sponsor
not 100% known but thats usually down to vga timings.GianDO wrote: Fri Oct 16, 2020 11:05 am so the fact that it doesn't show full screen is just a matter of firmware?
If it worked correctly it would be a great alternative to the other more expensive and hard to find scandoublers. Also because it seems to me that there are not many alternatives around ..terriblefire wrote: Fri Oct 16, 2020 11:10 amnot 100% known but thats usually down to vga timings.GianDO wrote: Fri Oct 16, 2020 11:05 am so the fact that it doesn't show full screen is just a matter of firmware?
- Admin sponsor
Personally I have not been interested in these kind of scandoublers because external ones are so good. Generally I want to use Amiga on standard TV.GianDO wrote: Fri Oct 16, 2020 12:13 pmIf it worked correctly it would be a great alternative to the other more expensive and hard to find scandoublers. Also because it seems to me that there are not many alternatives around ..
But can you get high resolutions even on standard TVs?terriblefire wrote: Fri Oct 16, 2020 12:20 pmPersonally I have not been interested in these kind of scandoublers because external ones are so good. Generally I want to use Amiga on standard TV.GianDO wrote: Fri Oct 16, 2020 12:13 pm
- Admin sponsor
Its never been something i wanted to do on Amiga
Ok, instead on my amiga 2000 I have a Picasso II and I would like to use it, but at the same time I would like to display the standard amiga resolutions without having to use two monitors ..
- 8 Bit Dreams
- Moderator Team
You should get one of Mazes Flicker Fixer cards, then
