Do I have the only 128mb TF536 in existence?
68030 + SDRAM + IDE
Re: Do I have the only 128mb TF536 in existence?
Post by JezC »
@PhilC Yes, I am working out what else I need for H4 #2 & H5 (plus what else I'm missing from the second TF536 & the two IDE boards), so will try to remember to add one of each of those (though I do already have a CF adaptor which is destined to go in my Falcon) before I place the order.
If I even had the time to program & fit the PAL for the 1.44M mode then I'd probably be much further forward :roll:
It would definitely be useful to have a CF image too - though I think the largest one I currently have is a mere 2G (plus a 256M & 32M)...but that would probably fit most of the available s/w with room to spare...
agranlund
Post by agranlund »
PhilC wrote: Tue Sep 29, 2020 5:06 pm Do I have the only 128mb TF536 in existence?
Yes, I think I do :lol: 8-)
Question is.. what are you going to fill up all that ram with? :D
WiseGreasyBastard
Post by WiseGreasyBastard »
One of my tf536 has 128mb also.
I haven't got around to sorted out a set of 6 roms with emutos to test yet though :roll:
@agranlund I have no idea what I'm going to use it for :stars:
@WiseGreasyBastard welcome to the 128 club :lol:
exxos wrote: Wed Sep 30, 2020 9:56 amRAM DISK ;)
Many of them
supaduper
Post by supaduper »
Just got 128mb to run on my TF330 :), it was using using one of the firmwares Steve was sending me to Test in the past to try and get the 128mb running,
Anyway I was bored and tried one of the firmwares and then manually added the Memory location using `ADDMEM` and I manged to get it to work, so I will forward the firmware to Alen to try
TF330 128mb.jpg (274.21 KiB) Viewed 3885 times
@supaduper Ok, you get to join the club too :lol:
WiseGreasyBastard
PhilC wrote: Wed Sep 30, 2020 9:07 am @WiseGreasyBastard welcome to the 128 club :lol:
Thank you, thank you very much :D
It that an @agranlund specially fondled version of emutos you have there or is there board tinkering to be done to get the memory recognised?
agranlund
Post by agranlund »
WiseGreasyBastard wrote: Wed Sep 30, 2020 7:08 pm It that an @agranlund specially fondled version of emutos you have there or is there board tinkering to be done to get the memory recognised?
You only need to flash it with the firmware for 128MB boards, no need for special versions of EmuTos :)
https://www.exxosforum.co.uk/forum/viewt ... =93&t=3442
Return to “TF536”
