will it compute? btl's attempt to build the H4
Re: will it compute? btl's attempt to build the H4
Hello,
i'm ordering the parts my local electronics store didn't have.
I have questions:
What frequency should QC1 and Q1 be?
Is the DS1315 mandatory?
Do your Serial+Parallel ports line up with the back edge of the mainboard? Mine are 2mm longer than the board.
It would be great if someone remembers where that info is, i'm still reading but can't find.
Greets,
btl
I have questions:
Greets,
btl
See the bottom of the post BOM.
https://www.exxosforum.co.uk/forum/viewt ... 167#p26532
Nope, just jumper the 2 pins marked on the MB if not using it. You also won't need the battery hold either.
@Icky Said there was no alignment issues.. I guess its possible different manufacturers may have some variations on stuff.btl wrote: Tue Dec 03, 2019 4:42 pm Do your Serial+Parallel ports line up with the back edge of the mainboard? Mine are 2mm longer than the board.
What info exactly ? Icky did a page you should look at https://www.exxosforum.co.uk/forum/viewt ... =73&t=2229btl wrote: Tue Dec 03, 2019 4:42 pm It would be great if someone remembers where that info is, i'm still reading but can't find.
Those Infos you just gave me, thanks! Of course i read the Build Guide, and also the known issues & fixes.What info exactly ? Icky did a page you should look at https://www.exxosforum.co.uk/forum/viewt ... =73&t=2229btl wrote: Tue Dec 03, 2019 4:42 pm It would be great if someone remembers where that info is, i'm still reading but can't find.
w00t,
Parts from mouser arrived, i can continue! SMD stuff first...
@btl , lets see some pictures of your efforts.
Here is what my board looks now
hi-res pic on google photos
SMD stuff is finished, i still need to get some connectors (Power) and some more jumpers.
I found out i got some resistors in wrong physical size.
Looks like your well on your way.
