Reading & write to RTC 12887 ?
Re: Reading & write to RTC 12887 ?
exxos wrote: Fri Jun 21, 2019 10:30 pm 6.jpg
So CS going high doesn't clear the selected address I think...
So the 68000 would put the address on the databus, CS = low, DS=low, but can't figure out what RW is supposed to be doing at that point :roll:
From my reading it doesn't look at the 'R/W' line until the read/write part of the cycle and that determines whether it reads the bus or writes onto the bus.
I mean the first bus cycle would select the register, then read or write data to it on the second bus cycle... but its unclear what RW is supposed to be during the register select cycle :stars:
Looking at the intel timings, RW is high in both register select cycles.. so assume thats the way to do it...
stephen_usher wrote: Fri Jun 21, 2019 10:59 pm From my reading it doesn't look at the 'R/W' line until the read/write part of the cycle and that determines whether it reads the bus or writes onto the bus.
That makes sense.. but why didn't they "XXXX" out the RW line in the timing diagram to just indicate "don't care" :shrug:
I assume as the Falcon has 2 registers for address and data, that it drives the "AS" pin on address, and doesn't for data. So the CPU must do 2 bus accesses to the RTC... and once the RTC has had the address "set" it stores it and can be accessed later in a second bus cycle.
On the memory map http://cd.textfiles.com/ataricompendium ... PPENDB.PDF it has "IO" for both.. but I don't know why it would be "IO" when it looks to only be a "write to register" on the RTC itself :shrug:
I guess it's possible the address register could be read or written to, but I don't really see the point in reading the address back.. As I assume operation would be write the address to the RTC, which selects that address, then read or write back from it.
I have emailed Maxim to see if they can clarify some things about it all. The whole datasheet seems to be a little vague :roll:
Only just got home, but quickly coded up the firmware and yes I used STOS as it just easier to poke stuff about..
Thankfully I am now seeing a "count" in the values.. Address zero is "seconds" register and its counting..
I think the problem I have now, is when I "peek and poke" it seems to be doing so on the high byte as I just get 255 all the time... but when I deek and doke, I can see it counting up every second, so it does look like I am getting the data.. I just need to mask the high byte on the databus to get a proper figure... will try and do that tomorrow...
Binary output makes more sense.. can see the binary counting up better for the seconds :)
Changing the address to "2" gives me %00000101 constantly, so as that is 10mins.. I suspect within the next 10mins it will change to %00000110....
EDIT2:
and yes it did!
:cheer: :cheer: :cheer:
I did a read of the address register and it gives 65535, so doing a read to the register basically isn't being driven, which was assumed to be the case anyway.
I guess poking the address on the bus doesn't matter in terms of the RW signal.. but to keep my sanity, I am basically doing a write to the register anyway.
The seconds count is a bit odd.. as basically once it gets to count of 10, it increased the "10 seconds" bits..
So it goes..
00000000 (0)
00001001 (9)
00010000 (10 seconds)
00010001 (11 seconds)
( 5 ) ( 9 )
0101 1001 (5x10 = 50 seconds + 9 = 59 seconds)
Very odd way of doing things :shrug: Will see if I can port over a proper 60 second dump next...
So the annoying thing is, the address has to be set each time the data is accessed :roll: You can't just set address zero and read it multiple times to get the data at that address... The address has to be set each time , which is a bit rubbish..
Below is a full debug of 60 seconds (0-59)
 %1111111100000000
 %1111111100000001
 %1111111100000010
 %1111111100000011
 %1111111100000100
 %1111111100000101
 %1111111100000110
 %1111111100000111
 %1111111100001000
 %1111111100001001
 %1111111100010000
 %1111111100010001
 %1111111100010010
 %1111111100010011
 %1111111100010100
 %1111111100010101
 %1111111100010110
 %1111111100010111
 %1111111100011000
 %1111111100011001
 %1111111100100000
 %1111111100100001
 %1111111100100010
 %1111111100100011
 %1111111100100100
 %1111111100100101
 %1111111100100110
 %1111111100100111
 %1111111100101000
 %1111111100101001
 %1111111100110000
 %1111111100110001
 %1111111100110010
 %1111111100110011
 %1111111100110100
 %1111111100110101
 %1111111100110110
 %1111111100110111
 %1111111100111000
 %1111111100111001
 %1111111101000000
 %1111111101000001
 %1111111101000010
 %1111111101000011
 %1111111101000100
 %1111111101000101
 %1111111101000110
 %1111111101000111
 %1111111101001000
 %1111111101001001
 %1111111101010000
 %1111111101010001
 %1111111101010010
 %1111111101010011
 %1111111101010100
 %1111111101010101
 %1111111101010110
 %1111111101010111
 %1111111101011000
 %1111111101011001
 %1111111100000000
So next I need to convert the bits over to some sane value which equals a actual seconds count...
My STOS conversion for seconds...
What I do is "bit test" bit 0, if its 1 then add one to S. If bit 1 is set, then add 2 to s, if bit 3 is set add 8 to s... and so on.
I've had it debugging to the screen and seems to work. So we are now counting in seconds 0-59 correctly :)
10 dim A(200)
20 for A=0 to 120
30 doke ($FF8960),0
40 ZZ=deek($FF8962)
50 Z$=str$(ZZ) : AA$=Z$
60 S=0
70 if btst(0,ZZ) then S=S+1
80 if btst(1,ZZ) then S=S+2
90 if btst(2,ZZ) then S=S+4
100 if btst(3,ZZ) then S=S+8
110 if btst(4,ZZ) then S=S+10
120 if btst(5,ZZ) then S=S+20
130 if btst(6,ZZ) then S=S+40
140 print A,bin$(ZZ),S
150 A(A)=ZZ
160 while Z$=AA$
170 doke ($FF8960),0
180 AA$=str$(deek($FF8962))
190 wend
200 next A
210 open out #1,"output.txt"
220 for A=0 to 120
230 print #1,A,bin$(A(A))
240 next A
250 close #1
Now I just noticed the second table in the datasheet where seconds and minutes can be read as binary :lol: :roll:
exxos wrote: Mon Jun 24, 2019 1:28 pm The seconds count is a bit odd.. as basically once it gets to count of 10, it increased the "10 seconds" bits..
So it goes..
00000000 (0)
00001001 (9)
( 5 ) ( 9 )
That's because it binary coded decimal.
