exxos's DFB1 trials
Re: exxos's DFB1 trials
@Badwolf Suggested a jumper for the flash for bank switching. So just added that in.
Post by JezC »
exxos wrote: Tue May 02, 2023 8:26 pm @Badwolf Suggested a jumper for the flash for bank switching. So just added that in.
@Badwolf stop distracting @exxos or it will never get sent off!
:slapface: :smackbum:
JezC wrote: Tue May 02, 2023 10:23 pm
Sorry about that :P
@exxos: it occurs to me that with a fixed SDRAM memory choice, you don't need the ALTRAM jumper -- you could repurpose that as the bank toggle, or relabel it OPTION2 for some futher choice down the line.
Badwolf wrote: Wed May 03, 2023 9:39 am @exxos: it occurs to me that with a fixed SDRAM memory choice, you don't need the ALTRAM jumper -- you could repurpose that as the bank toggle, or relabel it OPTION2 for some futher choice down the line.
Possibly.. or a altram disable jumper may be useful :shrug:
Though if my revision untimely goes in your GitHub then people may change stuff anyway. :shrug:
Finished the BOM . Had a bit of a fight with it all. The good thing is there is a script to export in JLC format. In eagle I had to write my own scripts to generate the BOM in the correct format. So good someone did a kicad script to do it.
exxos wrote: Wed May 03, 2023 2:35 pm Finished the BOM . Had a bit of a fight with it all. The good thing is there is a script to export in JLC format. In eagle I had to write my own scripts to generate the BOM in the correct format. So good someone did a kicad script to do it.
:bravo:
I think I may have made a proper BOM once for a board with only passives on it, but I never got very far with anything complicated! :)
Things are officially done in the Pacman logo stamped on it 8-)
It has been sent off to the PCB company for a quotation. Probably be a couple of days or so before I hear back.
New boards arrived.. and with typical stuff goes randomly wrong, impact can't find my programmer now :pullhair:
Impact has *never* worked for me. I use xc3sprog.
Badwolf wrote: Mon Jun 19, 2023 1:54 pm Impact has *never* worked for me. I use xc3sprog.
That always worked for me in till today. Though I was screwing around with all sorts of USB drivers when trying to get the pico drive to work properly. So something could have broke then :roll:
