ALPHA MODIFICATIONS
ALPHA MODIFICATIONS
Started a new thread for "must do" fixes and mods etc.
Re: ALPHA MODIFICATIONS
JUMPER PADS
SJ1 & SJ2 are the 2 solder pads like on the STFM near the blitter. Pads must be shorted when NOT using the blitter, and OPEN when using the blitter. For now I would suggest not fitting the blitter.
SJ5 is the clock line for the CPU, this needs to be soldered to allow 8MHz clock to CPU.
SJ3 & SJ4 Need to both be linked.
(Jumpers were there with intention of adding boosters without cutting tracks at a later date )
Jumper next to the ROM is the TOS104 / TOS102 select line.
RESET FIX
First is the short as found by icky on the reset circuit https://www.exxosforum.co.uk/forum/viewt ... 1171#p9633
The red circle shows the resistor shorting out VCC to the highlighted yellow line..
SOLUTION
STEP 1:
Cut the tracks on the bottom of the pcb where the yellow lines are.
STEP 2:
Solder a wire on the bottom of the PCB to join the pads highlighted with a yellow circle.
DONE:
exxos wrote: Mon Sep 10, 2018 10:05 am If anyone can post a image of this fix then it would help...
As requested two images. Excuse the messy soldering / flux etc on the underside :oops:
Track cuts are under the wire patch
IMG_3032 (1).png (367.9 KiB) Viewed 11066 times
Icky wrote: Mon Sep 10, 2018 10:24 pm As requested two images. Excuse the messy soldering / flux etc on the underside :oops:
:bravo:
HSYNC FIX
from here https://www.exxosforum.co.uk/forum/viewt ... t=90#p9961
I ballsed up the Hsync and it needs a fix to bypass the inverter...
exxos wrote: Sun Sep 16, 2018 10:30 pm HSYNC FIX
I just sat down to start doing some work on the board tonight and thought I would tackle this first.
Fix in place but am still getting horizontal scrolling as per video of boot before fix.
Will take a closer look at the circuit to see whats going on.
Realloy
Post by Realloy »
After cutting the trace on both sides of R920 ,,,, measure between D7 and the cut free R920 i get zero ohm, those two point must go to positive plane in pcb, so i guess no need to move the R920.
And also i noticed that the holes for the PSU is mirrored on the PCB.. Maybe you already know this..
Realloy wrote: Sun Sep 16, 2018 11:55 pm After cutting the trace on both sides of R920 ,,,, measure between D7 and the cut free R920 i get zero ohm, those two point must go to positive plane in pcb, so i guess no need to move the R920.
ahh yep, The left link wire isn't needed as the resistor itself actually connects to vcc.. will update the info...
Realloy
Post by Realloy »
i can see all the chips have a decoupling capacitor,,, but what about BAD DMA ? is there one and where? or is it not necessary?
